Hi everyone,
I have a problem which I can't fix since long time...
It is about "Cant view" text height...
I can't find where it can be changed! When I make my plans it is viewed like that:
I know it doesn't work like other views; because it seems that the menus of this label are incomplete..
I hope that anyone can help me...
Thanks in advanced!
I think that you might be stuck here. It seems that when the Superelevation View and Cant View styles were added to the software there was no option for controlling the text size or style. Unfortunately this issue has not yet been fixed, as far as I can tell.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
But it has to work with one base (or label), doesn't it?
Maybe with one command or something like that I can do something...
I need to have it solved!
There's no control for the text style or height in the Superelevation View Style. Changing the label style defaults has no effect on it either. I even tried changing all of the font files attached to the text styles in my drawing, and that didn't work either so it appears to be hard coded into the software somehow.
I'm fairly certain that what we have is a beta version of the code for this feature which was never completed. Perhaps someone from Autodesk would be able to comment further.
Steve
1- go to Text style by command "ST"
2-Find Which text Style used for Cant or Super elevation texting by Try and error
3-change it as you wish (I know there are not to many Option)
4- save and close.
