I have a drawing what have a template by defect, and i would change the original template by another in the same drawing.
Are there a way to do this?
Thanks in advance.
Solved by Jeff_M. Go to Solution.
Solved by arturopolanco. Go to Solution.
To copy styles from a template file to another drawing
Any style that is not contained in the current drawing will be copied from the template.
Major Kudos Arturo! Thats an amazing work around
Joe Bouza
Nice tip. Does it only work in C3D 2012? I tried it in 2009 and it didn't work but it definitely works in 2012.
That tip has been around since 2006.... super-secret-style-getter .... so it should work in 2009.
I guess I it does work in 2009; however, you have to be patient.
I started it at home and did not see any styles added to the drawing. When I got in the office all the styles were there. I just started the process again and have been waiting 10 minutes and still do not see the point styles.
That seems like a lot of extra steps. Here is how we have been doing this:
This will copy any styles that do not already exist in the current drawing. It will not overwrite existing styles. There are also some instances where expressions do not get copied correctly.
We have a library of style drawings that can be used to drag-and-drop sets of styles into a Civil 3D drawing as needed.
Something somewhat related to this post. I mistakely opened my template in student version. It had years of my work. And now I can not import the styles and settigns etc from it to the full version . I tried using the method you just advised (Autocad block for point marker) and also tried to import all the styles from Manage>Styles>Import. Nothing works. Any help would be appreciated
Find the last drawing you created using the template,erase everything out of it and save it as a dwt.
Keep a back up of your template in case this happens again.
