Civil 3D Forum
Change properties of a PLGRIDSYSTEM
13 REPLIES 13
Message 1 of 14
ericdaniel
8070 Views, 13 Replies
Is it possible to change the color, linetype, etc of a PLGRIDSYSTEM in Civil 3D 2012?
Eric
13 REPLIES 13
Message 2 of 14
in reply to: ericdaniel
Can you clue me in what a PLGRIDSYSTEM is? Not a recognized command in Civil 3D 2012.
Rick
Message 3 of 14
ericdaniel
Tha command is MAPLAYOUTREFERENCESYSTEM and creates a PLGRIDSYSTEM, which is a map grid with labels in paperspace, very handy, but I don't see any way to change it's properties.
I always dit it with points and a custom point and label style with Northing and Easting. Thanks,
Eric
Message 4 of 14
Jason.Hickey
Just from what I can tell, this isn't really that editable. You might want to post this question over on the Map3D Discussion group to see if any of those users have come up with a way to do this.
Jason Hickey
Premium Services Specialist
Autodesk, Inc.
Message 5 of 14
ericdaniel
in reply to: Jason.Hickey
I 'll do that
Eric
Message 6 of 14
Our company uses the command maploadgridstyle to load the styles from an XML file. I'm not well versed in XML but I've managed to modify the styles a little bit.
Does anyone know how to look up which CAD variables correspond to the command maploadgridstyle? I'm trying to set the default text precision in the xml file and am having trouble figuring out which variables are available to change.
Message 7 of 14
shamusmc
If you change the units of the drawing using the UNITS command prior to running the Reference System command that is how I found out how to control the precision.
Message 8 of 14
Hi!
please check my video
https://www.youtube.com/watch?v=3WGrWDRqeWA&lc=z130ffswfpurf33v022th5jbfonvgx2qv04
Simon Noyola
snoyola@d2et.com
Message 9 of 14
Very useful post - line types can also be changed - (case sensitive).
The linetype scale can be changed in the Properties for the PLGRIDSYSTEM.
Message 10 of 14
Izhar_Azati
in reply to: StevenMar
More Commands:
Command Group 'PrintLayoutCommands'
-MAPEXPORTLEGENDSTYLE, -MAPEXPORTLEGENDSTYLE
-MAPINSERTPLE, -MAPINSERTPLE
-MAPLEGENDPROPS, -MAPLEGENDPROPS
-MAPLEGENDSTYLE, -MAPLEGENDSTYLE
-MAPLEGENDUPDATE, -MAPLEGENDUPDATE
-MAPSETSCALEBARPROPERTIES, -MAPSETSCALEBARPROPERTIES
-MAPVIEWPORTSCALE, -MAPVIEWPORTSCALE
MAPASSOCVPWITHMAP, MAPASSOCVPWITHMAP
MAPCLASSICDRAWORDERHATCHONBOTTOM, MAPCLASSICDRAWORDERHATCHONBOTTOM
MAPCLASSICDRAWORDERTEXTONTOP, MAPCLASSICDRAWORDERTEXTONTOP
MAPCREATELEGEND, MAPCREATELEGEND
MAPCREATENORTHARROW, MAPCREATENORTHARROW
MAPCREATESCALEBAR, MAPCREATESCALEBAR
MAPDELETEMAP, MAPDELETEMAP
MAPDISASSOCVP, MAPDISASSOCVP
MAPDUPLICATEMAP, MAPDUPLICATEMAP
MAPEDITLEGENDSTYLE, MAPEDITLEGENDSTYLE
MAPEDITLEGENDSTYLE_ARG, MAPEDITLEGENDSTYLE_ARG
MAPEDITMAPPROPS, MAPEDITMAPPROPS
MAPEXPORTLEGENDSTYLE, MAPEXPORTLEGENDSTYLE
MAPHIDELAYERSINVP, MAPHIDELAYERSINVP
MAPLEGENDPROPS, MAPLEGENDPROPS
MAPLEGENDUPDATE, MAPLEGENDUPDATE
MAPNEWMAP, MAPNEWMAP
MAPNORTHARROWDEFAULTNORTH, MAPNORTHARROWDEFAULTNORTH
MAPSETCURRENTMAP, MAPSETCURRENTMAP
MAPSHOWALLLAYERSINVP, MAPSHOWALLLAYERSINVP
MAPUPDATELEGENDSTYLE, MAPUPDATELEGENDSTYLE
Command Group 'ACMAPGRIDSYSTEM'
-MAPLAYOUTREFERENCESYSTEM, -MAPLAYOUTREFERENCESYSTEM
-MAPLAYOUTREFERENCESYSTEMREMOVE, -MAPLAYOUTREFERENCESYSTEMREMOVE
-MAPLOADGRIDSTYLE, -MAPLOADGRIDSTYLE
MAPLAYOUTREFERENCESYSTEM, MAPLAYOUTREFERENCESYSTEM
MAPLAYOUTREFERENCESYSTEMREMOVE, MAPLAYOUTREFERENCESYSTEMREMOVE
MAPLOADGRIDSTYLE, MAPLOADGRIDSTYLE
(output from arx command).
Tags (3)
Message 11 of 14
We can change not only the color in the XML.
<LabelStyle>
<Format>
General|ZoneName|GridFull|GridAbbreviated|Grid1m|Grid10m|Grid100m|Grid1km|Grid10km|Grid100km|DMS|DD|HostPrec
</Format>
<Format>GridAbbreviated</Format>
<Offset>0.15</Offset>
<TextStyle>
<Font>Arial</Font>
<Height>0.1389</Height>
<Color>ff00DD00</Color>
</TextStyle>
</LabelStyle>
Message 12 of 14
bayuidr94
in reply to: Izhar_Azati
Can you change the blue line (gridline) into a tick?
Tags (2)
Message 13 of 14
Izhar_Azati
See:
AutoCAD Map 3D 2023 Help | How to edit the Reference System grid in AutoCAD Map 3D or Civil 3D | Autodesk
https://help.autodesk.com/view/MAP/2023/ENU/?caas=caas/sfdcarticles/sfdcarticles/How-to-edit-the-Ref...
Message 14 of 14
bayuidr94
i mean change the gridline into a crosshair
Rail Community
