Hey guys I have over 1500 pieces of text in lowercase letter and I want to make them all uppercase.
Is there a easy and quick way to do this?
Thanks!
Solved by Jeff_M. Go to Solution.
Sorry, but there is no native way to do this with multiple objects at the same time.
However, I would suggest posting this on the AutoCAD forums, as there may be someone over that that has created a custom LISP or something to do what you are looking for. Similar topics have been covered in the past, so that is probably your best route.
Saweet!!!
Thanks Guys. You know more then the AutoDesk employees!!!!
Haha
Wow, I totally missed that one. Thanks for pointing it out!
Bing a Civil3d forum and you being a Civil3d specialist I can understand why you thought what you though We wont pick on you
Highlight the text, hold down "shift" "ctrl" and press "u" and "l". this should change the text to upper or lower case.
I have noticed that Revit 2017 new text editor will not convert existing caps text to lower case text. And it will only convert existing lower caps to upper caps.
i like to use the Mtext - change to upper case for changing text to caps.
It can be done through EXPRESS tools.
Go to:
Express->Text->Change Text Case->(Select your choice viz. UPPER CASE/ lower case etc and press OK)
That's it
-bsrinivas, email: bsrinivas2006@yahoo.com
In Revit 2017 there is a way. Go to the text and double clock to edit. In the tool bar there will be a lower case a with an arrow to upper case A highlight the text to make upper case and clock the button.
this is the great way to change text case to caps by using online controls. it is very light
There's a quick and easy Dynamo script that can do that for you
https://www.youtube.com/watch?v=8EX8_mzO2fg
