AutoCAD Civil 3D General
randcdavidson
Message 21 of 28 (124 Views)
Re: Challenging Grading Project
10-09-2013 10:14 AM in reply to: randcdavidson
Reply to Troma. The pond bottom surface was created from the grading group properties. I was unaware that mattered?
troma
Message 22 of 28 (117 Views)
10-09-2013 10:40 AM in reply to: randcdavidson
Sometimes I create a surface from a grading, other times I just create a grading with no surface. When you said you couldn't find it to target it just seemed like the first logical thing to check.
If you have the surface, it shouldn't matter how you got it. I'm not sure why you can't target it.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Neilw
Message 23 of 28 (114 Views)
10-09-2013 11:10 AM in reply to: randcdavidson
I thought your objective was to grade from the top down to a relative elevation = -5'. Why do you need a separate bottom surface? All you need to do is add an infill after grading down at -5'.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
randcdavidson
Message 24 of 28 (102 Views)
10-09-2013 11:32 AM in reply to: Neilw
Well that was before they wanted the bottom to grade to the outfall. My objective is now to create the bottom surface with a set elevation at the outfall then grade out a half percent in all directions. Once that is complete the I must grade the top down at 3.5:1 to hit this newly created bottom surface. Thing is it's not showing up as an option in my target surfaces. I have included a pic of the bottom surface and what I have as a outfall area. What you will not see is the top of bank grading down yet.
Neilw
Message 25 of 28 (93 Views)
10-09-2013 11:40 AM in reply to: randcdavidson
Ok, I think it would be better to just add flowlines to get the bottom to drain.
WIN 7 64 PRO
RADEON 6450, 1 GB
Active Contributor
cwitzel
Message 26 of 28 (89 Views)
10-09-2013 11:42 AM in reply to: randcdavidson
Make surde it is in a different grading group.  You may not be able to see the "target" surface, because it is being created by the grading group you are using.  That is another reason to keep them in different sites.
If that still doesn't work, don't have it create the surface automatically add the grading to a different surface.
Conan Witzel
Active Contributor
cwitzel
Message 27 of 28 (69 Views)
10-09-2013 12:41 PM in reply to: cwitzel
Attached is an example drawing with the pond bottom surface and the pond top.
In this case graded at 2% using a feature line at the outfall and a grading object set to 250' @ 2%.  The top of the pond is then graded down to the pond bottom surface.
In both cases the resultant feature lines are added manually to the surfaces (Pond Bottom and Proposed)  There are also two sites.
randcdavidson
Message 28 of 28 (52 Views)
10-09-2013 01:36 PM in reply to: randcdavidson
Nice I'll try that out and see what kind of result I get. As you may have seen from my last image there is a "wall" where the outfall structure will be placed.  I have that to contend with as well.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
