Civil 3D Forum
Cannot extend structures in profile
4 REPLIES 4
nathan07
718 Views, 4 Replies
I have added a pipe network to my profile view and for some reason the structures do not extend down to the inverts of the pipe. So the pipes are lower than the structures. I tried changing the sump, and the rim to sump (rim to sump can be editted but immediately goes back to what it originally was when you click apply. I've also tried clicking the structure and extending it downwards but it doesn't change. I've tried changing the stye and still have the same issue. Any ideas?
4 REPLIES 4
Jay_B
in reply to: nathan07
Have you tried applying a structure rule "Set Sump depth=0" ?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
ccl_cad_manager
How far below above the pipe is the structure showing?  Could you have the pipe outer walls turned on and no thickness to the structure bottom?
MikeC
Civil 3D 2015, Win 7 64bit, 16 GB RAM, Dell M4600
''That's the way we've always done it'' is an excuse, not a reason.
ccoles
Are you sure the pipes are 'connected' to the structure? Graphically, in CAD they may look connected, but check the structure properties under the tab 'Connected Pipes' to see if they are reading as connected to the structure.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
wfberry
in reply to: ccoles
Easy way to check pipe connections, drag the structure, the pipes should follow.
Bill
Rail Community
