AutoCAD Civil 3D General
Active Member
Message 1 of 4 (1,825 Views)
Cannot change number of decimal places in elevation label
1825 Views, 3 Replies
05-07-2012 04:31 PM
The defaul label style for the Elevation of points is set to 3 decimal places. We are trying to change the elevation display to 2 decimal places. We have tried the directions in the following discussion: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/How-to-change-the-number-of-decimal-places-of-the-ele...
Which is:
Toolspace
->Settings
-->Drawing name
--->Edit Drawing Settings
---->Ambient Settings
----->Elevation
------>Precision -> We modify from 3 to 2 decimal places.
It does not modify the display settings.
Also:
Toolspace
->Settings
-->Drawing
--->Point
---->Label Styles
----->(right-click) Edit label styles
------>Layout
------->Text
-------->Contents
--------->click on the "..." (three points) button
(Open "Text Component Editor - Contents"
--------->Select Point Elevation in the driop down list.
---------->Precision: Set to 0.01
------------>Ok, Apply, etc...
This does not seem to work either.
Any suggestions appreciated.
Valued Contributor
Message 2 of 4 (1,816 Views)
Re: Cannot change number of decimal places in elevation label
05-07-2012 05:30 PM in reply to: fjperez
The second method is the one that will work.  You are probably forgetting to press the arrow button that applies the changes.  After you modify the precision you have to press the arrow that "applies" that change to the text field.  See attached image.
Distinguished Mentor
Message 3 of 4 (1,813 Views)
05-07-2012 05:34 PM in reply to: fjperez
When you make the change in the point style did you hit the arrow in the upper as shown. If you did not it does not push the setting to the style.Precision.png
C3D12-13
Win7x64 6gb
Active Member
Message 4 of 4 (1,782 Views)
05-08-2012 07:06 AM in reply to: fjperez
This worked perfectly. Thanks!
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
