Civil 3D Forum
Can you convert a feature line to a 3d polyline?
19 REPLIES 19
Message 1 of 20
learner12345
97145 Views, 19 Replies
Feature lines are easy to make and great for grading.  However, when I try to save the drawing into
*.dxf, all the feature lines disappeared.
Does this mean DXF files do not take feature lines?
I need the DXF files to up load into GPS.  Do I have to redraw everything in 3D polyline?
Or is there an easier way to convert feature lines into 3D polylines?
Thank you very much for your time!
19 REPLIES 19
Message 2 of 20
TerryDotson
in reply to: learner12345
The EXPLODE command should convert a selection set of FeatureLines to 3dPolys.
Message 3 of 20
Sorry that I want to confirm something as the follows:
Does the vertexes of your feature line or 3D polyline are with different elevations? If Yes, how can you give different elevation for those vertexes of your feature line or 3D polyline?
Thank you,
3D Visualization
Message 4 of 20
To 3D Visualization,
For feature lines you can right click and use elevation editor; for 3D polyline, I just go into porperties, and change the Z there one point at the time.
Message 5 of 20
tom_berning
The one thing to be careful of when exploding feature lines to 3d polylines is when you have feature lines crossing each other and one is establishing the elevation at that point on the other one. If you do not have verticies at the crossings, the 3d polylines will not reflect the same elevation at that crossing.
Tom Berning
Woolpert, Inc.
Civil 3D 2020
Message 6 of 20
I used Autodesk Civil 3D version 2002, I can edit 3D polyline with different elevation at different vertices, but I can't figure out how to edit 3D Polyline with different elevation at different vertices using Civil 3D version 2010? Any idea? Thanks.
Message 7 of 20
learner12345
in reply to: TerryDotson
To TerryDotson,
It worked very well, all the elevations got transferred over.  Thank you very much.
I was using "Save as" with *.dxf format.  It does not work well with feature lines.
Here is the right way to do it:
To export a drawing to a DXF file
  1. Verify that the drawing’s Model tab is selected.
  2. At the command line, enter UCS, and then enter World.
  3. Click  C3D (at the top left of the window) > Export > AutoCAD DXF.
  4. Enter a filename, and specify a path, if necessary.
  5. Click Save.
Message 8 of 20
I have test several times, they didn't work.
I need to express different elevation stations at a horizontal alignment, that is, combine a horizontal with vertical alignments.
Message 9 of 20
Thank you, Tom_Berning
It is good to know that !
To 3Dvisualization,
I am sorry that I can't help.  I am a new user, Civil 2012 is the first one I ever used.  Why don't you post a new message about this, I'm sure someone would know.
good luck!
Message 10 of 20
You can edit 3d polyline vertex elevations two different ways. You can use the properties window to edit each vertex and change the Z value or you can use the edit elevations from the modify tab of the ribbon then under feature lines, it is one of the smaller buttons. You can also type editfeatureelevs at the command line.
Tom Berning
Woolpert, Inc.
Civil 3D 2020
Message 11 of 20
in 2012, if you click on the vertice number in porperties, you can move from point to point.  you can sign different horizontal with vertical alignments to each of them.
not sure in 2010...
Message 12 of 20
Three ways didn't work. When change a vertex elevation, other vertices elevations are automatically changed to the same elevation. You can test a 3D polyline with several vertices, you will understand. I am sure there must be a key, but I can't find out. Could you find out for me?
Thank you
Message 13 of 20
List one of the polylines and post the list (or a portion of it) so we can see what you're working with. You should have no problem changing the elevation of an individual vertex.
Allen
Allen Jessup
CAD Manager - Designer
Message 14 of 20
When you edit a 3D Polyline (created with 3dPoly command) there is a section in the Properties dialog that lists the vertex infomation. You can move down the polyline to the vertex you need to modify and set the elevation there.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Message 15 of 20
wfberry
in reply to: AllenJessup
He said is version is Civil 3D 2002, which I believe cannot be correct.  I believe that 2004 was the first but hardly worth much.
Bill
Message 16 of 20
Sinc
in reply to: wfberry
There was limited access to a 2004 incarnation, along with a public "preview" version in 2005.  The first "official" version was 2006.  Similarly, not worth much...  Smiley Wink
It wasn't until the 2009 version that it really got "ready for prime time".
Sinc
Message 17 of 20
amrfooda2008
Thank you so much.that is so ease and useful
Message 18 of 20
sam.therres
Exploding the feature lines works for me as long as my feature line is NOT in Site1.  Put your featurelines into a new site before exploding.
Message 19 of 20
sam.therres
Looking a bit deeper it appears that the real culprit it in the site properties - 3d geometry tab
Make sure that the site display mode is set to "use elevation" before exploding feature lines.
Message 20 of 20
AllenJessup
in reply to: sam.therres
Having two threads running concurrently about the same problem is getting confusing. http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Exploding-featurelines-to-3D-Polylines/m-p/45...
Allen
Allen Jessup
Rail Community
