AutoCAD Civil 3D General
Active Member
learner12345
Message 1 of 20 (9,846 Views)
Can you convert a feature line to a 3d polyline?
9846 Views, 19 Replies
07-13-2011 09:29 AM
Feature lines are easy to make and great for grading.  However, when I try to save the drawing into
*.dxf, all the feature lines disappeared.
Does this mean DXF files do not take feature lines?
I need the DXF files to up load into GPS.  Do I have to redraw everything in 3D polyline?
Or is there an easier way to convert feature lines into 3D polylines?
Thank you very much for your time!
Valued Mentor
TerryDotson
Message 2 of 20 (9,843 Views)
Re: Can you convert a feature line to a 3d polyline?
07-13-2011 09:55 AM in reply to: learner12345
The EXPLODE command should convert a selection set of FeatureLines to 3dPolys.
Active Contributor
3Dvisualization
Message 3 of 20 (9,824 Views)
07-13-2011 10:38 AM in reply to: learner12345
Sorry that I want to confirm something as the follows:
Does the vertexes of your feature line or 3D polyline are with different elevations? If Yes, how can you give different elevation for those vertexes of your feature line or 3D polyline?
Thank you,
3D Visualization
Active Member
learner12345
Message 4 of 20 (9,816 Views)
07-13-2011 10:59 AM in reply to: 3Dvisualization
To 3D Visualization,
For feature lines you can right click and use elevation editor; for 3D polyline, I just go into porperties, and change the Z there one point at the time.
Distinguished Contributor
Message 5 of 20 (9,809 Views)
07-13-2011 11:05 AM in reply to: learner12345
The one thing to be careful of when exploding feature lines to 3d polylines is when you have feature lines crossing each other and one is establishing the elevation at that point on the other one. If you do not have verticies at the crossings, the 3d polylines will not reflect the same elevation at that crossing.
Tom Berning
Woolpert, Inc.
Civil 3D 2013
Active Contributor
3Dvisualization
Message 6 of 20 (9,803 Views)
07-13-2011 11:16 AM in reply to: Tom_Berning
I used Autodesk Civil 3D version 2002, I can edit 3D polyline with different elevation at different vertices, but I can't figure out how to edit 3D Polyline with different elevation at different vertices using Civil 3D version 2010? Any idea? Thanks.
Active Member
learner12345
Message 7 of 20 (9,803 Views)
07-13-2011 11:18 AM in reply to: TerryDotson
To TerryDotson,
It worked very well, all the elevations got transferred over.  Thank you very much.
I was using "Save as" with *.dxf format.  It does not work well with feature lines.
Here is the right way to do it:
To export a drawing to a DXF file
  1. Verify that the drawing’s Model tab is selected.
  2. At the command line, enter UCS, and then enter World.
  3. Click  C3D (at the top left of the window) > Export > AutoCAD DXF.
  4. Enter a filename, and specify a path, if necessary.
  5. Click Save.
Active Contributor
3Dvisualization
Message 8 of 20 (9,795 Views)
07-13-2011 11:25 AM in reply to: learner12345
I have test several times, they didn't work.
I need to express different elevation stations at a horizontal alignment, that is, combine a horizontal with vertical alignments.
Active Member
learner12345
Message 9 of 20 (9,789 Views)
07-13-2011 11:28 AM in reply to: 3Dvisualization
Thank you, Tom_Berning
It is good to know that !
To 3Dvisualization,
I am sorry that I can't help.  I am a new user, Civil 2012 is the first one I ever used.  Why don't you post a new message about this, I'm sure someone would know.
good luck!
Message 10 of 20 (9,789 Views)
07-13-2011 11:31 AM in reply to: 3Dvisualization
You can edit 3d polyline vertex elevations two different ways. You can use the properties window to edit each vertex and change the Z value or you can use the edit elevations from the modify tab of the ribbon then under feature lines, it is one of the smaller buttons. You can also type editfeatureelevs at the command line.
Tom Berning
Woolpert, Inc.
Civil 3D 2013
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
