I have a surface that I want to edit. It is telling me I can't because it's on a locked layer. The problem is, none of the layers are locked. The surface isn't object locked, the point group isn't locked. It's saying some of my survey figures are on a locked layer, I have a feeling that those are the problem, but aside from unlocking all the layers in the drawing, I can't think of anything else to change. I can not figure out what the deal is with this surface... Any help would be much appreciated.
@rhdins wrote:.......none of the layers are locked.
and
@rhdins wrote:....but aside from unlocking all the layers in the drawing....
If "none of the layers are locked", then why are you concerned about "unlocking all the layers in the drawing"?
Don Ireland
Engineering Design Technician
@rhdins wrote:
... but aside from unlocking all the layers in the drawing, I can't think of anything else to change. I can not figure out what the deal is with this surface...
That tells me you do have locked layers in your drawing. Is Layer 0 one of them?
Allen Jessup
Allen Jessup
CAD Manager - Designer
If there is some other way to unlock layers besides clicking on the "lock" icon in the layer manager, then maybe. But otherwise, they are all unlocked. I made sure every single layer was unlocked and still get the "object is on locked layer" message. It tells me this for my survey figures too.
If we're truly going to be able to help you, then we're going to need to see your dwg file.
Don Ireland
Is there anything else that may complicate the surface? Was it pasted,data-shortcutted, copied, etc? Are you trying to add elements to the definition or just rebuild it?
If it doesn't appear in the Layer Manager there shouldn't be a locked layer. You can try the command line -Layer, Unlock, * .
Allen
Allen Jessup
I have survey figures in the drawing that I am using as breaklines. If those lose the connection to the survey database, would that cause this problem?
I have some new survey points that I want to add to the surface. The surface won't rebuild because it says it's on a locked layer. That's the problem I'm having.
Here is the surface,
https://dl.dropboxusercontent.com/u/20051252/PG0011202_New%20Surface.dwg
I'm going to have to leave this for someone else. I can't open the file as I'm on C3D 2012.
Don Ireland
I can't open it either (running 2012). Have you tried an audit?
It may have gone through the twilight zone but when I opened the file ALL the layers were locked. I unlocked all and I was able to remove a breakline or two and it rebuilt.
Bill
Windows 7 x 64 Professional
Nvidia GeForce 9800 & 8500
12 GB Ram
i7 965 @ 3.20 GHz
Corsair Force 240 GB SSD
Infrastructure Suite 2014 Premium SP1
Obviously I've got something weird going on. I downloaded my file and opened that, it showed all the layers as locked for a split second, then they all switched to unlocked. But the drawing still treats everything as if it's locked!
Do I have something set wrong somewhere??
Here is a screen grab, showing my layers unlocked, and that the surface is locked. (the little thing by my cursor is the lock symbol)
Your image shows that they're LOCKED.
This is what the layer dialog will look like if the layer is unlocked.
Don Ireland
Your screenshot shows all the layers as Locked. Yellow + closed padlock = locked. Blue plus open padlock = unlocked.
Allen
Allen Jessup
I wish I had a better excuse than just being dumb...
In my hurry I was thinking, yellow on, blue off, ugh. Thanks for the help though. It will keep you guys sharp!
Another solution is to select the surface, go to Surface Properties, Information tab, and then make sure to uncheck the "Object Locked" box. (See attached image)
