Civil 3D Forum
Can't see surface
6 REPLIES 6
djocwf54
4045 Views, 6 Replies
Can't see surface
I know my surface is there but somewhere I have turned it off. Grrrrr.
Not on a Monday morning and a rush job to beat. I know the surface is there but I'm not able to see it.
Can you paste a surface from a different dwg?
6 REPLIES 6
ccl_cad_manager
in reply to: djocwf54
First: Make sure all your Layers are turned on
Open Toolspace:
+Surfaces
Right Click on Surface Name
Left Click on Surface Properties.
Information Tab: change the surface style to just about anything to see if the surface comes in.
Also: check the lightbulb in the lower right hand corner of your Civil 3D window.  Make sure it's yellow and not red.  If it is red, right click in your drawing window, select Isolate object, and end isolation.
MikeC
Civil 3D 2015, Win 7 64bit, 16 GB RAM, Dell M4600
''That's the way we've always done it'' is an excuse, not a reason.
djocwf54
in reply to: ccl_cad_manager
I keep losing my surface.
I created it last night and was ready to print it and this morning its gone.
The elevation labels are there but the surface is not.
All the layers are on and I did what you suggested yet there is no surface.
Actually this is a different dwg than the one when i first posted this question.. No clue here what I did.
rl_jackson
Check LEVEL OF DETAIL - TURN IT OFF
Will its good in theory it does not work as expected.
Rick Jackson
Survey CAD Technician VI
djocwf54
in reply to: rl_jackson
That did it thanks so much and have a most awesome day
much appreciated
                        dj
rl_jackson
No problem, I had the same issue some time back, and was getting only a partial view of the surface - I bet my head for about a hour trying to figure it out.
You may also want to set LOD to OFF in your template so that the issue does not come up again.
Rick Jackson
daphne.couri
View tabViews panelLevel of Detail
Rail Community
