Hi.
I received a drawing from one of our consultants and somehow can't open any version of it they've sent.
Already tried recovery and referencing.
I don't which version of Civil 3D they use but my is 2013.
However I can open it in DWG Viewer and Global Mapper.
Any ideas?
Solved by antoniovinci. Go to Solution.
You could try to open it in Autodesk Trueview, then convert to an older DWG release...
Are you getting any specific error about it not opening? Have you tried a Partial Open? Can you open it in Design Review?
Allen Jessup
Allen Jessup
CAD Manager - Designer
Glad he could help you.
Allen Jessup
Allen Jessup
I was only lucky, gentlemen...
I'm still wondering why Vasily's C3D 2013 cannot open the original drawing: perhaps has it been created by a 2014 release?
Mark Green
Working on Civil 3D in Canada
According to Autodesk a 2014 drawings should open in 2013 and have the Civil 3D objects usable. In any case it should have opened in 2013 with proxy objects if nothing else. Maybe it was exported from another piece of software and was supposed to be compatible but wasn't quite. You'd have to pick apart the drawing file to find out. The only thing I know how to tell from a drawing file is what version it was produced in.
Just good that TrueView was able to rescue it. I wonder if any Civil 3D objects survived. I wouldn't think so.
Allen Jessup
Allen Jessup
@ Vasily
Could you paste here the first 6 characters of the original .DWG opened in Notepad..?
That would be an AutoCAD 2007 release drawing file. So if it's the original file, it would be from an old version of the program. It also might have been a Save Back. Some trouble might have been created if the drawing was only saved back to the earlier version instead of using Exporttoautocad.
That's all speculation anyway.
Allen Jessup
Allen Jessup
We are having problems opening some of our drawings as well.
Recently, our IT department upgraded our existing XP computers (32 bit) to new W7 machines (64 bit). We reinstalled AutoCAD C3D 2012, with ARD and Stringer including all Service Packs
This upgrade seems to have gone well with a few exceptions.
One or two of our drawing cannot be opened on the new 64 bit W7 computers.
They are typical drawing with nothing out of the ordinary in them
Opening these particular drawings runs as usual till it gets to 93% complete
An AutoCAD Application box appears with....
AutoCAD Application has stopped working
Windows is checking for a solution to the problem...
Then
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Then AutoCAD shuts down.
I can then load the same drawing onto the XP machine without problem. I have purged out the drawing, resaved it but still it closes in W7 computer.
Any suggestions
Mark Green
