AutoCAD Civil 3D General
Active Member
Message 1 of 11 (507 Views)
Can't offset a horizontal alignment to create a pline
507 Views, 10 Replies
12-19-2012 09:44 AM
This is with Civil 3D 2013.  I am able to create a pline by offsetting an alignment using any drawing on any other workstation in our office, but on my machine I get an error: "1 object(s) were filtered out." when I try to select the alignment.
This leads me to searching for some system variable or something that is different on my machine.  Has anyone else come across this?
Thanks.
*Pro
Message 2 of 11 (504 Views)
Re: Can't offset a horizontal alignment to create a pline
12-19-2012 10:00 AM in reply to: fcopley
reboot, and reload?
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Message 3 of 11 (474 Views)
12-19-2012 03:57 PM in reply to: fcopley
I'm going to guess that you're selecting not the alignment, but something on top of it, like the station labels, by accident.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Message 4 of 11 (443 Views)
12-20-2012 06:44 AM in reply to: fcopley
Any locked layers in the drawing?
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Member
Message 5 of 11 (434 Views)
12-20-2012 07:48 AM in reply to: fcopley
Thanks for all the suggestions, but none seem to make a difference.  Time for a proper wipe and reinstall, I guess.
Message 6 of 11 (430 Views)
12-20-2012 08:08 AM in reply to: fcopley
There are a few other error finders I would try.  You say this is only one machine; is it also only one drawing, or any alignment in any drawing?  What happens if you log into windows as different user?
Active Member
Message 7 of 11 (424 Views)
12-20-2012 08:40 AM in reply to: troma
That does narrow it down.  It works fine logged in as another user on my machine.  It seems to be any alignment in any drawing.
Thanks.
Message 8 of 11 (422 Views)
12-20-2012 08:45 AM in reply to: fcopley
What do you get if you log into windows as yourself and then choose a different C3D profile in the options dialogue?
Active Member
Message 9 of 11 (418 Views)
12-20-2012 08:54 AM in reply to: troma
It seems to be the same using any profile.
But I did just realize that it will in fact work for me if I select the alignment first and then issue the offset command.
Thanks.
Active Member
Message 10 of 11 (414 Views)
12-20-2012 09:03 AM in reply to: troma
Okay, I sort of solved this by overwriting some of my user files in \AppData\Roaming\Autodesk\C3D 2013\enu from another user.  I would still like to have a better idea of what caused it.
Thanks, troma for your suggestions.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
