We are unable to get layout mode in Civil 3D to show the subassembly the way that it does in Subassembly Composer. Any ideas?
Has anyone had luck posting a pkt file? I keep getting an error that the file contents don't match the file type. I renamed to .txt and it still didn't work.
Thanks in advance,
Tim
You can add a decision to the subassembly to test for layout mode. On the true branch you can add points and links to tell it how to draw the subassembly in layout. The false branch will be used in roadway (corridor) mode. See the following thread for a little more info: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Subassembly-Composer-Viewing-Alternatives/m-p...
Thanks, David!
Tim
