I've set the corridor's surfaces to use the corridor boundariy & the datum's overhang correction to top links & bottom links, but for some reason it doesn't respect the corridor's boundary. Any idea what's happening?
Thanks for any help.
Solved by sboon. Go to Solution.
Typically when a corridor surface boundary fails it's because you have a bowtie or some other location where the corridor overlaps itself. Are there any error messages in the panorama when you rebuild?
