AutoCAD Civil 3D General Discussion
*Expert Elite*
Joe-Bouza
Message 1 of 27 (402 Views)
Accepted Solution
Can someone do an UNDO test for me?
402 Views, 26 Replies
10-15-2013 06:21 AM
I have experineced severe UNDO isues with 2013 & 2014 creating hundreds of grouped commands in the UNDO buffer making it impossible for me to deploy to the rest of the company. If I use the OOTB 2013 ot 2014 dwt file it does not happen but when I try to include our style it gets fouled up. It doesn't matter if I open saveas, insert explode, or import styles, the same UNDO problem comes into the picture.
So, if you currently DO NOT have an UNDO issue in either version I would appreciate it if you can see if my 2012 dwt causes the problem on your system. just rename to dwt
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
*Expert Elite*
Jeff_M
Message 2 of 27 (383 Views)
Re: Can someone do an UNDO test for me?
10-15-2013 06:50 AM in reply to: Joe-Bouza
Have you seen THIS post, Joe?
Jeff_M, also a frequent Swamper
*Expert Elite*
AllenJessup
Message 3 of 27 (373 Views)
10-15-2013 07:45 AM in reply to: Joe-Bouza
OK, Joe. I started off with my 2012 template and brought it into 2014 in a few different fashions. I never experienced the Undo problem.
I then worked with your template and got these results.
Opened your 2012 template directly in 2014 - Undo Problem Occurred.
Opened an new 2014 dwg with no template and recovered your 2012 template in 2014- Undo Problem Occurred.
Opened an new 2014 dwg with no template and used the Sincpac import styles- Undo Problem Occurred.
Opened an new 2014 dwg with no template and used the Civil 3D IMPORTSTYLESANDSETTINGS - NO Undo Problem Occurred.
Have you tried this method? It looks like one or more of your Styles are frelled. Either the Civil 3D command ignores it or fixes it.
My tests involved drawing a closed polyline and the zooming and panning. Combine Zoom and Pan Commands was on. Remember. The Inteli-Pan and Inteli-Zoom (Scroll wheel pan and zoom) will generate more Undos than the command line. But with my last try I never got the massive amount of "Group of Commands" Undo list as with the first three.
HTH
Allen Jessup
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
*Expert Elite*
Joe-Bouza
Message 4 of 27 (355 Views)
10-15-2013 08:11 AM in reply to: AllenJessup
Hi Allen
Yes I tried all of the methods you mention. Could you convert and email me 2013 and 2014 that don't get undo probs? It would be greatly appreciated.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
AllenJessup
Message 5 of 27 (346 Views)
10-15-2013 08:20 AM in reply to: Joe-Bouza
Joe, I'll do the 2014. We never installed 2013, a little triscadecaphobic I think. If you don't get one set in a few days. Let me know. I can install 2013 at home.
Allen
*Expert Elite*
Joe-Bouza
Message 6 of 27 (340 Views)
10-15-2013 08:28 AM in reply to: AllenJessup
Triskaidekaphobia! cool - you don't get to use that to often
no worries 14 would be great!
It seems to be related to the mouse scroll an pan. If you use the keyboard all is hunky-dory
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
AllenJessup
Message 7 of 27 (325 Views)
10-15-2013 09:02 AM in reply to: Joe-Bouza
Joe,
Turned out to be a little more complicated than I thought. I'd accidentally stumbled across the correct combination to do this successfully. I didn't realize this until I tried to just import the Styles and Settings and ended up with a drawing that had the same Undo problem. So I had to go back and recreate the process.
I don't use the IMPORTSTYLESANDSETTINGS as lot. So when I first brought the dialog box up I stated experimenting with some of the buttons along the top. I figured that it might have to do with checking and unchecking the conflicting styles. I found out that if you don't do anything. You'll end up with a template with an Undo problem If you click on the last button "Uncheck Conflicting" and the the second to last button "Check Conflicting". You'll get a template with with NO Undo problem.
After running a comparison between the new 2014 template and the original 2012 template. I would guess the offending Style is a QTO Material Table Style called Area and Volume.
I've sent you the 2014 template. Try this method and see if it works in 2013.
Allen
*Expert Elite*
Joe-Bouza
Message 8 of 27 (303 Views)
10-15-2013 10:48 AM in reply to: AllenJessup
Thanks Allen
I still get the issue but it is only with pan zoom via mouse wheel. Now that I now how to deal with it it is a little more palettable
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
*Expert Elite*
AllenJessup
Message 9 of 27 (296 Views)
10-15-2013 11:06 AM in reply to: Joe-Bouza
Joe,
Do you have LevelOfDetail on? I've noticed that generates a lot of "Group of Commands" in the Undo list when using the scroll wheel. You don't see so may if it's off. I'm working with it on so I accepted generating a half dozen ± for each zoom or pan as more of less normal. I also get more when I Zoom, Pan then Zoom rather than when I zoom out and back in.
Allen
*Expert Elite*
Joe-Bouza
Message 10 of 27 (294 Views)
10-15-2013 11:07 AM in reply to: AllenJessup
2d top wire frame. :smileysad:
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
