I have a corridor with conditional assembly for all 200 sections. One conditions which stretches 200 feet I can not get the daylight link to show in the sections. Any suggestions?
Thank you so very much. some of the questions you asked my may help me to trouble shoot the problem.
If this is limited to a single "Region" of your corridor take a good look at your Targets etc. within that region.
Also be sure to view the Panorama and work through any errors that may exist such as targets not found when rebuilding the Corridor.
I think Jay_B has the right idea with double checking the panorama for errors.
Also, double checking the setting in the conditional. I believe it has a minimum and maximum width setting. If the solution falls outside of this range the link won't show up. This will show up in the panorama as an error as well.
If a link is not displaying in section view, I would look at the link code names assigned to the daylight link subassembly, and the link styles assigned to that code name in the code set assigned to the section view.
Earlier in the thread,you showed a screen shot of a cross section that failed -- what was that station? Can you take a screen shot of THAT section within the section editor (since you said it works in the editor)? And zoom out some.
Also using the actual cross section, draw a line at 3:1 to show us where it should be daylighting. Give us a screenshot of that too.
Don Ireland
Engineering Design Technician
Also: is this section actually taken at a station where an assemply has been show? Or is this section BETWEEN assembly insertions?
Don Ireland
