AutoCAD Civil 3D General
Joe-Bouza
Message 1 of 11 (361 Views)
Can PDF size be reduced
361 Views, 10 Replies
01-17-2013 05:40 AM
Is there a setting that can reduce the sized of a PDF plot? I currently use DWGtoPDF.pc3 and I plotted a 13 sheet set that came out at 35MB. If I plot them as individuals some are 500K and some are 6MB; probably due to images.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
AllenJessup
Message 2 of 11 (358 Views)
Re: Can PDF size be reduced
01-17-2013 06:11 AM in reply to: Joe-Bouza
Joe,
Not that I'm aware of in AutoCAD Civil 3D. Adobe Standard will do it. I use an inexpensive program, CutePDF Pro, to do it. You can download a trial version. There will be degradation to the images. You'd actually have to try it to see if it would be acceptable.
Another thing that might help is if you reduced the image size outside of AutoCAD and repathed the attached images to the smaller versions.
Joe-Bouza
Message 3 of 11 (356 Views)
01-17-2013 06:12 AM in reply to: AllenJessup
Thanks Allen. I thought that to be the case. I have tried those options you suggest.
Thank you
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
AllenJessup
Message 4 of 11 (348 Views)
01-17-2013 06:30 AM in reply to: Joe-Bouza
Have you tried printing with an external PDF printer like CutePDF (the free version)?
Joe-Bouza
Message 5 of 11 (346 Views)
01-17-2013 06:32 AM in reply to: AllenJessup
That I have not. I'll try the download. The problem I have there is I would need every workstation to get it, no? Which means I would have to go around installing
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
AllenJessup
Message 6 of 11 (337 Views)
01-17-2013 06:59 AM in reply to: Joe-Bouza
Yeah. I just throw the install file on the network and visit each workstation.
Valued Mentor
TerryDotson
Message 7 of 11 (324 Views)
01-17-2013 07:25 AM in reply to: Joe-Bouza
Post or email me one and I'll let you know what's inside.
klugb
Message 8 of 11 (318 Views)
01-17-2013 07:40 AM in reply to: Joe-Bouza
Have you tried to reduce the resolution in the plotter settings before printing? I have one setup for 150 DPI when dealing with aerials. It's usually about half the size and very little loss in clarity.
Bruce Klug
AutoCAD Expert Elite
AutoCAD Civil 3D 2014 Certified Professional
Infrastructure Design Suite 2014 (SP1)
Testing Civil 3D 2015
Win 7 Pro, 64-bit
Joe-Bouza
Message 9 of 11 (314 Views)
01-17-2013 07:44 AM in reply to: klugb
Thats the button I could not find! Thanks I'll report back
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Joe-Bouza
Message 10 of 11 (303 Views)
01-17-2013 08:10 AM in reply to: klugb
Chopped of 10 megs
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
