What is the best AutoCAD software to design aquaculture facilities (fish farms) in?
1) I need to create 3-d models of Pipes and Tanks and show water flow.
2) I need to animate my 3-D models to show water flow
3) I need to pop in the dementions of the tanks and have the software automaticly draw that tank or pipe
4) I need to post images and animations on the web
5) I need to reduce the file siszes of the images and animations so I can email them and post them online
6) I need to create animations of pumps, water falls, streams and ponds
7) I need to create 3-d models of plans
😎 I need to create animation of alge and show different densities of waste in the water.
9) I need to take a camera eye and move it through the systems pipes and tanks
10) I need to show flow rates of water ... can I just enter a number for the flow rate and see the resualt?
Other questions:
How much time will it take to learn the software before I can build and animate a fish farm?
Where should I learn this software?
Can I just use 3-D stuido Max to do all of this?
"BuildFishFarms"
I don't think Civil 3D is the tool you should be looking at. It is better suited for modeling the site (roads, parking lots, sewer and drainage systems).
It may be Autodesk Plant software is better suited for modeling the piping systems you would be working with. Or some of the other modeling and animation products would suit you. I don't know enough about those other products to make any recommendations but at least you can eliminate Civil 3D.
