Civil 3D Forum
Can I save a copy of a Survey Database before I translate?
6 REPLIES 6
Scuttlebutt95
596 Views, 6 Replies
I have a project that I need to move to a different coordinate system in order to meet regulatory guidelines.  Currently the project is in an "assumed" coordinate system that I don't want to lose because we have been working in that system for a long time.  I would like to copy the database (including figures, etc) to create another one (with a different name of course) that I will then translate to the required coordinate system.  Is the only option to Export an XML, create a new Survey Database & then import that XML?
6 REPLIES 6
Pointdump
in reply to: Scuttlebutt95
SB,
Here's a thread that discusses that very topic:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Drawing-Template-Set-Default-Survey-Database-...
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Scuttlebutt95
in reply to: Pointdump
Thanks for the response, but all I see in that other topic is instruction for exporting Survey Database settings- not copying or exporting Survey Database data and settings.
Pointdump
SB,
That's what you do. First export the settings, then use them as a "template".
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
SB,
Here's more:
http://civilintentions.blogspot.com/2012/08/pre-configure-survey-database-settings.html
Dave
Dave Stoll
Las Vegas, Nevada
mfernandes
So essentially you want a backup or a copy.!
Hopefully I got it right.
In file explorer make a copy and rename your Survey db folder.
In C3D select the Survey db collection, right click and refresh.
Will that work. I have done it and have not run into issues.
rl_jackson
in reply to: mfernandes
That only works if you using a separate folder for the database and the project, I have my sdb set to populate in my project folder, thereby keeping the drawing, and other files together with the database. This is were things are completely lacking in C3D with regards to project management, and the linking of the sdb to the drawing.
Rick Jackson
Survey CAD Technician VI
Rail Community
