Civil 3D Forum
Can I join alignments same like polylines ?
5 REPLIES 5
iflorintheo
1122 Views, 5 Replies
Hello guys.
Please tell me a way how to join 2 alignments which are continuing a same road? Is it even possible ?
I have tried to explode them into polylines > join the polylines and then reconstruct the alignment again but it crashes on everything longer than 15 miles.
Civil Engineer / Infrastructure of metropolitan transports
http://civil3design.wordpress.com/
5 REPLIES 5
Have you tried adding a station equation in the Alignment Properties?
Todd Rogers
Hi Todd,
Yeah that was the first comming into my mind. The last alignment starts at the station where the first finishes, and their coordinates are the same.
Joe-Bouza
in reply to: iflorintheo
Nope can't join alignments. as for crashing on 15 miles you may want to try a Map cleant on the pline first. IMHO polylines mak crappy alignment. I suggest extending the longer of the two by editing 1 of them with the alignment tool bar and trace the other
Your Name
Your Name
iflorintheo
in reply to: Joe-Bouza
That's not helping me man cause the point was to evade this step. Anyway I have found a way by joining 2 alignments very easy, especially on a huge highway project. I use export to Land XML and edit the coordinates manually.
Joe-Bouza
Way to go man.
accept you own solution its a good one
Your Name
Your Name
Rail Community
