AutoCAD Civil 3D General
Member
Message 1 of 3 (153 Views)
Can I get my structure label to stop flipping?
153 Views, 2 Replies
10-14-2013 11:04 AM
Is there a way that I can get a small angle between my leader and the landing? When I get to a certain angle, the text flips. I can't place the text exactly where I want it because of this. I've tried changing the Readability Bias angle in the label style but that didn't work.
Member
Message 2 of 3 (96 Views)
Re: Can I get my structure label to stop flipping?
10-22-2013 12:49 PM in reply to: phllygrl
Are you viewing the object/label through a viewport?
Is it a Data Shortcut?
I would be inclined to change the orientation reference on the label to View if through a Viewport.  You can always create a copy of the label style if this is the only label that you want to be displayed different than the rest.
Active Contributor
Message 3 of 3 (83 Views)
10-22-2013 11:18 PM in reply to: phllygrl
If I am understanding your issue correctly (I think we have the same issue) you are unable to place Structure Labels directly above or below the Structure that you wish to label... As soon as you move too close to vertical the Label 'Flips' to the other side, which can be a pain when you need to move the label to avoid clashes etc. Unfortunately, as far as I am aware there is no way around this. Hopefully this can be fixed some time soon.
Regards
Ross
Currently using Civil 3D 2013 & 2014 SP1
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
