Hello I'm a civil engineering student. Recently I came to to know about autocad civil 3d. My query is would I be able to perform works that an autocad 3d model expert can do with just autocad 3d?? I'm in a bit of confusion about selecting one of them. Also I need to be able to autocad 3d drafting. Can anyone please help?
Civil 3D is Autodesks Civil Engineering program. It is built on both plain AutoCAD and Map 3D. There may be a couple of commands from plain AutoCAD that are disabled in Civil. Mainly those that might disturb the coordinates or units. For Civil Engineering you should be using Civil 3D.
There are a few things that might be confusing at first. A Civil 3D surface is not an AutoCAD surface. A Civil 3D Cogo point is not an AutoCAD point. But I can't think of anything you can do in plain AutoCAD that you can't do in Civil 3D.
Allen
Allen Jessup
CAD Manager - Designer
And if you just want to use C3D as plain AutoCAD, just use the "AutoDesk AutoCAD Civil3D as AutoCAD" shortcut created in your Start Menu (Start Screen) and most of the C3D interface is gone and it looks like plain AutoCAD.
