Civil 3D Forum
CUT/FILL LABELS ARE OVERLAPPING
7 REPLIES 7
Message 1 of 8
913 Views, 7 Replies
I'm setting up a cut/fill label style with cut labels in red with a negative sign. The fill labels are in green with the negative sign dropped. This worked out great. However, my cut labels are still showing the fill/positive labels in red. It seems that they are overlapping with the fill labels so that they are not printing correctly. The fill labels are printing brown/black instead of green. Any ideas on which setting will control this? Attached is a .pdf of the print results.
Thanks.
7 REPLIES 7
Message 2 of 8
dhenderhan
in the Fill style editor, change the sign field to 'hide negative value'
David E. Henderhan, PLS
Civil 3D 2023
Dell Precision 3660 - Windows 10 Pro 64-bit
Intel (R) RTX A2000
12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz
128 GB ram
Message 3 of 8
Thanks for responding quickly. The fill labels are working correctly. I'm having troubles with the cut labels. Attached is another .pdf showing cut labels with both positive & negative values. How do I dump the positive values in a cut situation? If you have any ideas, please let me know.
Message 4 of 8
Hidden_Brain
please see attached screenshots, i have "hide negative value" for fill and "sign negative" for cut, which seems to be giving me desired results.
Message 5 of 8
Sorry, but this issue is not solved. I also have these setting and it is not working. Any other ideas why this is not working correctly?
Message 6 of 8
mathewkol
Attach a drawing.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 7 of 8
in reply to: mathewkol
Thank you for taking a look at this drawing.
Message 8 of 8
mathewkol
This is the best way to accomodate your needs.
http://www.civil4d.com/2008/06/dynamic-surface-cut-fill-ticks-finally/
Matt Kolberg
Rail Community
