AutoCAD Civil 3D General Discussion
Valued Contributor
jnjhuz
Message 1 of 8 (485 Views)
CUT FILL CONTOURS
485 Views, 7 Replies
05-16-2013 05:06 PM
IS THERE A WAY TO MAKE CONTOURS THAT ARE GREEN THE CUT AREAS AND RED IN THE FILL?
*Expert Elite*
neilyj
Message 2 of 8 (461 Views)
Re: CUT FILL CONTOURS
05-17-2013 12:31 AM in reply to: jnjhuz
There certainly is.....assuming you are using a volume surface
Go to surface Properties and change analysis to Contours, 2 ranges and set values/colours/linetype manually to suit and Apply
Then go to Surface Style and edit Contour Ranges > Set Colour Scheme > True. If using 2014 beware of the "software feature as designed" that means you will have to redo the contours colour/interval etc after a rebuild. This "feature" dies not affect releases prior to 2014...:smileyfrustrated:
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
*Expert Elite*
troma
Message 3 of 8 (440 Views)
05-17-2013 06:44 AM in reply to: neilyj
I've never done this, but I think I would want three ranges, not two. I would want one in the middle, with just the zero contour. This way you can make the zero contour plot black (or blue, or whatever you want).
How does the 0.00m contour plot when you have it included in both ranges?
Credit where credit is due! Give kudos or accept as solution whenever you can.
*Expert Elite*
mathewk
Message 4 of 8 (428 Views)
05-17-2013 07:46 AM in reply to: troma
If there are 2 ranges and 0 is the end of the first one and the beginning of the second, the colour is based on the first (top) entry within the analysis.  At least, that's how it works in my experience.  If you want the 0 contour a different colour, then yes, 3 ranges would be prudent.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
*Expert Elite*
neilyj
Message 5 of 8 (418 Views)
05-17-2013 09:19 AM in reply to: mathewk
Agreed - make a centre range (say -0.05 +0.05) and another line colour. Although to be fair the OP did ask for red and green, if the contours are labelled then the 0 contour colour isn't perhaps as important??
neilyj
*Expert Elite*
troma
Message 6 of 8 (415 Views)
05-17-2013 09:33 AM in reply to: neilyj
I'm more along the lines of asking for advice than giving it in this conversation. It's something I've thought of doing, never done it. Thanks for confirming my suspicions!
Valued Contributor
jnjhuz
Message 7 of 8 (366 Views)
05-21-2013 08:32 AM in reply to: troma
I don't know I've never done it, but I think I know what you mean.
Valued Contributor
jnjhuz
Message 8 of 8 (366 Views)
05-21-2013 08:34 AM in reply to: neilyj
Thanks, I'm going to try this.
Announcements
Need installation help?
