Civil 3D Forum
CUT FILL CONTOURS
7 REPLIES 7
Message 1 of 8
jnjhuz
1031 Views, 7 Replies
CUT FILL CONTOURS
IS THERE A WAY TO MAKE CONTOURS THAT ARE GREEN THE CUT AREAS AND RED IN THE FILL?
7 REPLIES 7
Message 2 of 8
neilyj666
in reply to: jnjhuz
There certainly is.....assuming you are using a volume surface
Go to surface Properties and change analysis to Contours, 2 ranges and set values/colours/linetype manually to suit and Apply
Then go to Surface Style and edit Contour Ranges > Set Colour Scheme > True. If using 2014 beware of the "software feature as designed" that means you will have to redo the contours colour/interval etc after a rebuild. This "feature" dies not affect releases prior to 2014...Smiley Frustrated
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 8
troma
in reply to: neilyj666
I've never done this, but I think I would want three ranges, not two. I would want one in the middle, with just the zero contour. This way you can make the zero contour plot black (or blue, or whatever you want).
How does the 0.00m contour plot when you have it included in both ranges?
Mark Green
Working on Civil 3D in Canada
Message 4 of 8
mathewkol
in reply to: troma
If there are 2 ranges and 0 is the end of the first one and the beginning of the second, the colour is based on the first (top) entry within the analysis.  At least, that's how it works in my experience.  If you want the 0 contour a different colour, then yes, 3 ranges would be prudent.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 5 of 8
neilyj666
in reply to: mathewkol
Agreed - make a centre range (say -0.05 +0.05) and another line colour. Although to be fair the OP did ask for red and green, if the contours are labelled then the 0 contour colour isn't perhaps as important??
Message 6 of 8
troma
I'm more along the lines of asking for advice than giving it in this conversation. It's something I've thought of doing, never done it. Thanks for confirming my suspicions!
Mark Green
Message 7 of 8
jnjhuz
in reply to: troma
I don't know I've never done it, but I think I know what you mean.
Message 8 of 8
jnjhuz
Thanks, I'm going to try this.
Rail Community
