Civil 3D Forum
COPY/PASTE problem
20 REPLIES 20
Message 1 of 21
rutar
25815 Views, 20 Replies
COPY/PASTE problem
Hello!
In this video is shown what "strange" objects appear after copy/paste via clipboard.
1. Opened "talv.dwg",  INSERT block "rihtimine 3tee" with "explode" option enabled.
2. Trying to copy some objects via clipboard into the same file.
 - first try - no sucsess;
- second try -   some set of lines appeared, like "grass' hatch.
- third try - another unwanted shape - set of lines like two rectangles one above another.
Only these two unwanted shapes appear with this copy/paste via clipboard issue.
Somtimes no problem (like in video - opened new file, and pasting here - was sucsess), sometimes nothing been copied, sometimes those strange shapes.
Also we have a problems with inserting of BLOCKS with this issue.
talv.dwg link:
https://skydrive.live.com/redir?resid=D99EA11F0AA70C9A!9151&authkey=!AOFR-289ashaCDM
PS. This first videofile a littile bit large - about 1.8Mb, so I uploaded to youtube :
http://www.youtube.com/watch?v=OPGO4c9b_fo&feature=youtu.be
Second similar attempt is attached to this post.
Can anybody help us?
20 REPLIES 20
Message 2 of 21
troma
in reply to: rutar
Not much time to watch videos right now, sorry.  But one question: are you pasting objects from a newer version of C3D back to an older version?
Mark Green
Working on Civil 3D in Canada
Message 3 of 21
rutar
in reply to: troma
Thank you for reply,
Versions are the same.
Earlier I asked this question on AutoCAD 2013 forum - here is more detail about this issue:
http://forums.autodesk.com/t5/AutoCAD-2013/2013-Copy-Paste-problem/td-p/3666864
Message 4 of 21
echecani
in reply to: rutar
Intenta con esto, es un aplicativo (lisp).
Eddy
Message 5 of 21
AlmasSuljevic
in reply to: rutar
I tried to replicate your issue on one of the tutorial drawings and with your talv.dwg and each time copy/paste worked fine. I used right-click copy/paste as well as CTRL+C/CTRL+V and COPY command withing AutoCAD with no difference.  See video: http://screencast.com/t/3nTXbzVqbY
It seems that you may be having some issues with your installation. I'd suggest running repair and trying it with any of these draiwngs: C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Help\Civil Tutorials\Drawings
Good luck!
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 6 of 21
C3D_TomR
in reply to: AlmasSuljevic
I typically find that a lot of times it's only the profile that's corrupt. For this reason I create a copy of the default Civil 3D profile for everyday use then if there's an issue such as this one I have the user try to duplicate the issue in the default C3D profile. If the issue doesn't happen in the default C3D profile then the username profile gets renamed to "bad" and I rebuild the new username profile from the default C3D profile again.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Message 7 of 21
Joe-Bouza
in reply to: rutar
I should have taken troma's advice. I watched your video for about 3.5 of the 6 minutes and cannot discern what you are trying to show.
But I have to ask the question: Why wouldn't you simply use the copy command to copy this object? I use the clip board but not a big fan of its use.
I have people that use it to create blocks on the fly and end up with drawings full of blocks with names like AC$44F556R67UPL8Y972.
Lots of fun when you want to count something
Your Name
Your Name
Message 8 of 21
rutar
in reply to: Joe-Bouza
Hello!
Q: "Why wouldn't you simply use the copy command to copy this object?"
A: I need to copy objects from one file to another.
This issue is investigated, and lot of thanks to Kean Walmsley.
The bug was in the file - huge amount of unreferenced strokes, that we cannot purge with usual "-purge".
After running this awesome DGNPURGE utility - filesize is more than 50% less, and Copy/Paste - works!
Regards.
Message 9 of 21
peterros
in reply to: rutar
Hi rutar,
Please can you share thsi tool?  I have the same problem, but I'm a complete disaster on programing.... I'm just an architect Smiley Wink.
Peter
Message 10 of 21
sarch
in reply to: rutar
Do  you have a compiled dll file for DGNPURGE I am having compile problems with the code.
I have a very lareg project where users cannot copy paste bcuse of the DGN data.
Thankyou in annticipation
Stella
Message 11 of 21
stellaarch
in reply to: rutar
Thankyou for the Clinv dll.
I havenetloaded  this in AutoCAD 2012 and AutoCAD 2013 and run the application on a problem dwg file.
In 2012  when I type in CLINV   command does not exist
in 2013  I get the message "Unhandled exception has occurred in a component in your application. eNotAllowedFor This Proxy"
Sorry to be a pain but can you assit please
Regards Stella
Message 12 of 21
rutar
in reply to: stellaarch
we have sometimes "eNotAllowedFor This Proxy" exception too.
Do Audit and Purge before using it.
And run it on 64bit machine, not 32.
Otherwise you can try WBLOCK method.
http://www.theswamp.org/index.php?topic=42086.0
Ruslan.
Message 13 of 21
Ajilal.Vijayan
in reply to: sarch
Message 14 of 21
rutar
in reply to: Ajilal.Vijayan
Thank you for link.
We using from Keans Walmsley's sources  compiled DGNPURGE utility.
Do you know is this issue is present on C3D 2014 too?
Message 15 of 21
muhad.imran84
in reply to: rutar
hi,
i am also facing same problem.even i have few no of text in my file but the size showing 10MB please send me the solution.
Message 16 of 21
Message 17 of 21
rutar
in reply to: muhad.imran84
You can use Autodesk DGN Hotfix to solve the problem.
Message 18 of 21
rutar
C3D 2015 it seems already have solution.
Message 19 of 21
muhad.imran84
in reply to: rutar
hi good day,
thank you very much for your info.
I just run the same command and procedure and now I get rid from this.
M.Imran
Message 20 of 21
sarch
in reply to: rutar
Do you know if the new function to "Automatically purge orphaned data" is also included in 2015LT.  I use the application dgnpurge2012 but need full Autocad to run it.
 Thank you Stella
Rail Community
