Distinguished Contributor
bigmaz
Message 1 of 5 (307 Views)
COGO points duplicating along crown of corridor
307 Views, 4 Replies
03-19-2012 04:50 AM
Hi guys
I have created COGO points from my corridor, there seems to be 2 sets of points ontop of each other along the crown of the road.  They are different numbers, so its not the same point twice, anyone know why it would do this?
Martin
AllenJessup
Message 2 of 5 (302 Views)
Re: COGO points duplicating along crown of corridor
03-19-2012 05:26 AM in reply to: bigmaz
I don't know. Are they at the same elevation?
Allen
Active Member
chd4trichard
Message 3 of 5 (298 Views)
03-19-2012 06:28 AM in reply to: bigmaz
You're probably generating points for multiple codes at centerline, such as pave1, pave 2, subgrade, etc...  You can create points from the horizontal and vertical alignments that define the corridor using "Create Points- Alignment- Divide/Measure Alignment" if all you need is finish grade at centerline.
sboon
Message 4 of 5 (289 Views)
03-19-2012 08:36 AM in reply to: bigmaz
The lane subassemblies have an option to turn the crown point codes on or off.  If you have this option turned on for both sides of the road then you'll get duplicate featurelines and probably duplicate points created along the crown.  Check your assembly and try turning off the crown option for one side.
bigmaz
Message 5 of 5 (259 Views)
04-19-2012 09:39 AM in reply to: sboon
Thanks SBoon, thats what the problem was, it was taking both subassemblies points :smileyhappy:  thanks so much for this.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
