Civil 3D Forum
CIVIL 3D 2014 CONNECT TO DATA
4 REPLIES 4
vcoleman
707 Views, 4 Replies
UNKNOWN COMMAND "MAPCONNECT".   I am in planing and Analysis.  Actually no commands work .
4 REPLIES 4
ccoles
in reply to: vcoleman
It works on our system. We just upgraded to C3D-2014. Maybe a bad install?
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
AllenJessup
It works here in 2014 and has always worked in previous versions. Start with restarting the program. If that doesn't work. Reboot the computer.
If neither of those works you can check if the Planninganalysis Partial CUI is attached.
After that I'd suggest a repair. If none of that works. You may have to reinstall the program.
Allen Jessup
Allen Jessup
CAD Manager - Designer
vcoleman
Figured it out, by doing a google search.  Demandload needed to be set to 3 and mine was set to 1
AllenJessup
Good work. Mine is set to 3 so that's why I didn't notice. Thanks for posting the answer.
Allen
Allen Jessup
Rail Community
