Valued Contributor
bo.martin
Message 1 of 3 (188 Views)
C3d 2013 Structure Change
188 Views, 2 Replies
09-24-2012 05:50 AM
I'm learning pipe network's....
I need to change a structure type and I can't seem to find
where I can change it.
TIA
Bo
Valued Mentor
ccoles
Message 2 of 3 (183 Views)
Re: C3d 2013 Structure Change
09-24-2012 06:44 AM in reply to: bo.martin
It's easy. Click on the structure to highlight it, then right-click for the pop-up menu. On that menu, there's a command to 'Swap Part...'. It brings up the part catalogue to pick the next part to change it to. Be aware that this also updates the part description, so you may want to check that after you swap the part.
If the pop-up menu doesn't show a 'Structure Properties...' or 'Swap Part...', there must be 2 or more items highlighted. Hit ESC a couple of times and try again.
Windows 7 64-bit
HP Z600 8 Gig RAM
Civil 3D 2013
Valued Contributor
bo.martin
Message 3 of 3 (167 Views)
09-24-2012 07:55 AM in reply to: ccoles
That got it.
You have to do it in plan view. In the profile view the swap part option wasn't there.
Thanks!!
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
