Workspaces > Planning and Analysis > Map Setup > Coordinate System Library button i get some JIT error AGAIN. Seriously getting tired of fighting Civil 3D.
How do i fix this error? see attaached image
FULL ERROR:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
OSGeo.MapGuide.MgCoordinateSystemLoadFailedException: The coordinate system load failed. ASTRLA66-Grid_to_WGS84
at OSGeo.MapGuide.GeometryApiPINVOKE.SWIGExceptionHelper.ThrowCustomException(String className, IntPtr cptr)
at OSGeo.MapGuide.GeometryApiPINVOKE.MgCoordinateSystemEnum_Next(IntPtr jarg1, Int32 jarg2)
at OSGeo.MapGuide.MgCoordinateSystemEnum.Next(Int32 ulCount)
at Autodesk.Gis.UI.CoordinateSystem.DataAccess.CSDefinitionLibrary.LoadPaths(ReportProgressDelegate reportProgress)
at Autodesk.Gis.UI.CoordinateSystem.DataAccess.CSDefinitionLibrary.get_Paths()
at Autodesk.Gis.UI.CoordinateSystem.ViewModel.CSLibraryViewModel.FireScopeChangedImpl()
at Autodesk.Gis.UI.CoordinateSystem.ViewModel.CSLibraryViewModel.<FireScopeChanged>b__19(Object bkWorker, RunWorkerCompletedEventArgs bke)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Window.ShowHelper(Object booleanBox)
at System.Windows.Window.ShowDialog()
at Autodesk.AutoCAD.ApplicationServices.Core.Application.ShowModalWindow(IntPtr owner, Window formToShow, Boolean persistSizeAndPosition)
at Autodesk.Gis.Map.CoordinateSystem.Commands.AcMapCoordSysCommand.ExecuteLaunchCommand()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.269 (RTMGDR.030319-2600)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 19.0.0.0
Win32 Version: 19.0.55.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcdbMgd.DLL
System
Win32 Version: 4.0.30319.269 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.0.30319.233 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
AdApplicationFrame
Assembly Version: 0.0.0.0
Win32 Version: 3.5.19.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AdApplicationFrame.DLL
AdWindows
Assembly Version: 3.5.21.0
Win32 Version: 3.5.21.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AdWindows.DLL
PresentationFramework
Win32 Version: 4.0.30319.275
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
Win32 Version: 4.0.30319.275 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
Win32 Version: 4.0.30319.282 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/Acmgd.DLL
System.Configuration
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcWindows.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcCui.DLL
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AeccUiWindows
Assembly Version: 10.0.1111.0
Win32 Version: 10.0.1111.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AeccUiWindows.DLL
AeccUiWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AeccUiWindows.resources.DLL
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AcWindows.resources.DLL
PresentationUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
AecMgdReverse
Assembly Version: 7.0.50.0
Win32 Version: 7.0.50.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AecMgdReverse.DLL
AecRibbon
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AecRibbon.DLL
AmbercoreEngine
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AmbercoreEngine.DLL
AmberCore.IsdCodecAPI.Core
Assembly Version: 5.0.0.343
Win32 Version: 5.0.0.343
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AmberCore.IsdCodecAPI.Core.DLL
EmbeddedSQLiteLoader
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/EmbeddedSQLiteLoader.DLL
AcMapInfoCenter
Assembly Version: 16.0.36.2
Win32 Version: 16.0.036.2
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcMapInfoCenter.DLL
AeccPartPublishingWizard
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AeccPartPublishingWizard.DLL
C3DVSP3D
Assembly Version: 3.2.0.0
Win32 Version: 3.2.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/C3DVSP3D.DLL
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcWindows.dll
AeccUiMgd
Win32 Version: 10,0,1111,0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AeccUiMgd.DLL
AeccPressurePipesMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AeccPressurePipesMgd.DLL
AeccContextTabRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AeccContextTabRules.DLL
AcMapRibbonWrapper
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcMapRibbonWrapper.DLL
AcMapRibbon
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcMapRibbon.DLL
AeccWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AeccWindows.DLL
System.Windows.Forms
Win32 Version: 4.0.30319.278 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
ManagedMC3
Assembly Version: 6.4.0.0
Win32 Version: 6.4.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/ManagedMC3.DLL
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AcLayer.resources.DLL
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AeccDbMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AeccDbMgd.DLL
AcLivePreviewContext
PresentationFramework.Luna
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcWelcomeScreen
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcWelcomeScreen.DLL
AcWelcomeScreen.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AcWelcomeScreen.resources.DLL
AcMrUi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcMrUI.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AcMrUi.resources.DLL
AcMr
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcMr.DLL
System.Runtime.Serialization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
AcMapResourceManagement
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcMapResourceManagement.DLL
ResourceManagerRdfImp
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/ResourceManagerRdfImp.DLL
System.Data
Win32 Version: 4.0.30319.237 (RTMGDR.030319-2300)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Autodesk.IDM.AutoCADEmbedded
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/Autodesk.IDM.AutoCADEmbedded.DLL
Autodesk.IDM.Embedded
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/Autodesk.IDM.Embedded.DLL
AecBaseMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AecBaseMgd.DLL
AcLayerTools
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcLayerTools.DLL
AcLayerTools.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AcLayerTools.resources.DLL
AcCommandToolTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcCommandToolTips.DLL
AcCommandToolTips.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AcCommandToolTips.resources.DLL
VerticalTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/VerticalTips.DLL
AeccUiTooltipContent
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AeccUiTooltipContent.DLL
AeccUiTooltipContent.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AeccUiTooltipContent.resources.DLL
AcDialogToolTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcDialogToolTips.DLL
AcDialogToolTips.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AcDialogToolTips.resources.DLL
AcXrefUtil
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcXrefUtil.DLL
AcUnderlay
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcUnderlay.DLL
AcUnderlay.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AcUnderlay.resources.DLL
Connect.Client.AutoCAD
Assembly Version: 3.0.84.0
Win32 Version: 3.0.84.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/Connect.Client.AutoCAD.DLL
AeccHydroCalcsMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AeccHydroCalcsMgd.DLL
AeccUiTaskDialogContent
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AeccUiTaskDialogContent.DLL
AeccUiTaskDialogContent.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AeccUiTaskDialogContent.resources.DLL
Autodesk.Gis.ObjectModels.LayerDefinition-2.4.0
Assembly Version: 2.4.0.5642
Win32 Version: 2.4.0.5642
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/Autodesk.Gis.ObjectModels.LayerDefinition-2.4.0.DLL
AcCustomize
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcCustomize.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/en-US/AcCustomize.resources.DLL
AcMapLoader
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/acmaploader.arx
ConvertText
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/ConvertText.DLL
MapPublishImp
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/MapPublishImp.DLL
OSGeo.MapGuide.PlatformBase
Win32 Version: 1.0.0.1
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/OSGeo.MapGuide.PlatformBase.DLL
OSGeo.MapGuide.Foundation
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/OSGeo.MapGuide.Foundation.DLL
Autodesk.Map.Platform
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/Autodesk.Map.Platform.DLL
Autodesk.MapGuide.Studio.Site
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/Autodesk.MapGuide.Studio.Site.DLL
AcMapFeatureEntityTooltipsManager
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcMapFeatureEntityTooltipsManager.DLL
AcMapCoordSysManagedUi
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AcMapCoordSysManagedUi.DLL
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/Autodesk.Gis.UI.CoordinateSystem.DLL
Autodesk.Gis.Map.ToolUtils
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/Autodesk.Gis.Map.ToolUtils.DLL
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/OSGeo.MapGuide.Geometry.DLL
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/Autodesk.Gis.Map.CoordinateSystem.Commands.DLL
Autodesk.Gis.UI.WizardFramework
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/Autodesk.Gis.UI.WizardFramework.DLL
System.Deployment
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
AecArchMgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202013/AecArchMgd.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
lhampton wrote:How do i fix this error?
What about downgrading to a safer C3D 2012, sir..?
I second that.
In fact I did not start using C3D12 exclusively until they release the 2.0 service pack..
I find that it pays to wait a while before upgrading, lot less heart ache in the long run, just wish Adesk would stop doing the yearly release cycle, it generally creates more problems than it fixes.
In regards to your post - You might try re-installing .NET
Rick Jackson
Survey CAD Technician VI
