Did you try Don's suggestion of processing only a small portion of your
project?
Some of my work requires corridors at 2' intervals. I wouldn't dream of
running these until I ran them at 50' (or more) to be sure I had everything
correct, such as surface selections, etc. If you're trying to create the
section views, try ONE ONLY and see what happens. If it works, try 5
sections. If that works, start working your way through the project to see
where it is getting stuck.
wrote in message news:5071740@discussion.autodesk.com...
Hello everyone and thank for your response,
I have made radical changes to the design file. Cut down the TIN model
severely (approximately 80% cut!), cleaned out the file using your kindly
suggested methods (purge, audit etc.) but without any result. Even
recreation of design in a new file does not help. I am now considering
reinstalling the program for a further try.
As pointed out by Bill earlier I did not mention anything about maschine or
OS I'm running the program on so here are my main specs:
Program: Civil 3D 2006, Service Pack 2 + Hotfix 2.
OS: Windows XP pro SP2 including most recent updates.
PC: Dell Precision 370
Intel P4, 3.2 GHz
1.00 GB of RAM
ATI FireGL V3100, 128 MB Configured for AutoCAD
