AutoCAD Civil 3D General
jtshumpert
Message 1 of 5 (120 Views)
C3D San. Pipes
120 Views, 4 Replies
04-19-2012 05:15 AM
Did Autodesk give us the option in pipe networks to change the bottom linetype to something different than the top linetype in profile?
Ex. Sanitary linetype has dashed on top and solid on bottom.....
JTS
http://civil3dit.com/
*Expert Elite*
jmayo
Message 2 of 5 (106 Views)
Re: C3D San. Pipes
04-19-2012 06:15 AM in reply to: jtshumpert
The outer lines should be the same and the inner lines should be the same. Perhaps you have a line or another object that coincides with the bottom of pipe line? Did you regen the display?
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
jtshumpert
Message 3 of 5 (100 Views)
Re: C3D San. Pipes
04-19-2012 06:28 AM in reply to: jmayo
No. We have to display the TOP linework as a linetype dashed or center and the bottom would be solid.
Inner and outer.
JTS
*Expert Elite*
jmayo
Message 4 of 5 (97 Views)
Re: C3D San. Pipes
04-19-2012 06:35 AM in reply to: jtshumpert
I misunderstood. The pipe style will not do that OOTB. You can draw linework or a profile over the bottom of pipe to get the look you need for plotting.
You can use part builder to create a custom pipe family that has a negligible wall thickness so you can set up a style that displays the outer wall as center and the inner wall as solid.
John Mayo, PE
IDSP 2014
Employee
dana.probert
Message 5 of 5 (67 Views)
Re: C3D San. Pipes
04-19-2012 11:48 AM in reply to: jmayo
I wonder if adding a solid flow line to your pipe label (maybe the line is the only component in the label) would help.
Dana Probert, P.E.
Technical Marketing Manager, Civil Engineering
Blog: BIM on the Rocks
Learn More About BIM for Infrastructure
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
