I was testing an imperial survey file with its equivalent as a metric survey file. I created points at all the property corners of the imprial survey file. Then I exported the points with LandXML. I thought LandXML would translate the points to the new coordinate / metric system once imported into the metric survey file. I was surprised to learn that the points did not change to metric or the new coordinate system. So it appears that if I want to use these points to test the integrity of the metric file for its new coordinate location and metric scale, then I have to use the Map3d functionality inside Civil 3D by performing a query and translating the points from imperial to the metric coordinate/scale. Is my understanding correct, that LandXML will not translate the point data or am I missing something?
Solved by AllenJessup. Go to Solution.
Solved by rl_jackson. Go to Solution.
Rick Jackson
Survey CAD Technician VI
Your answer is correct working within the program. I just find it faster and more reliable to run the PNEZD file through Corpscon. That way you produce a metric PNEZD file quickly and with good control of the Vertical Datum.
Allen
Allen Jessup
CAD Manager - Designer
