I am using Civil 3D 2014.
I am looking for a lisp routine or program that can set a files coordinate system without having to open the file, if its even possible.
Thanks in advance for any suggestions.
Solved by BlackBox_. Go to Solution.
CE,
Corpscon looks promising. I'm still trying to figure out how it works. Several people on this Forum have praised it.
Dave
Dave Stoll
Las Vegas, Nevada
set the coordinate system in what kind of file, a C3D .DWG file?
I suspect it's possible using something like this: http://www.lee-mac.com/odbxbase.html
Dave,
Corpscon works on external point files like a PNEZD.csv. It doesn't work directly on drawings. I think it's great because it's fast, easy to use and does vertical transformations. Plus it's Free!.
Allen
Allen Jessup
CAD Manager - Designer
Allen,
I downloaded it after your glowing recommendation in another post. I opened it, but it's not intuitive. I'm going to read the PDF "manual" today. It does look promising.
Dave
Dave Stoll
Las Vegas, Nevada
Dave,
I have used Corpscon for individual csv translation but do not believe it can set the coordinates of a dwg file. All I need to do is toggle the coordinates of a drawing file to a coordinate system without having to open the file. I have several files and was looking for a quick way to accomplish setting their coordinate systems.
So, I looked into the AutoCAD Map API for setting Coordinate systems on a batch of drawings. It looks like the script would have to open each drawing to set it.
There is also a method in Civil 3D's API as well, and again would require opening the drawings to access the CivilDocument's Settings object.
If you don't have too many drawings to update, performance shouldn't be that bad, but getting the script to wait for the drawing to completely open before processing is a hassle sometimes.
Usually for batching drawing, I like AutoCAD's ReadDwgFile method, which opens the drawing in memory and lets you iterate the block tables. But that's not where the zones are stored.....
If it's something you'd like to go through with, you can PM or email me.
Mike
Maybe @BlackBox_ could comment on this....
Odoshi,
Thank you for that insight. It sounds like it is the same: if I open the file manually or write an application to open the drawing in order to access the coordinate settings. So a batch process to update a drawing file's coordinates without opening the file is not an option. Is my understanding correct?
This looks like it might be useful. I haven't done anything like this in a long time. Back in the day we'd use a batch file to open the drawing, call a script that would run a lisp. Thing have changed since then.
Allen
Allen Jessup
@rkmcswain wrote:
@rkmcswain wrote:set the coordinate system in what kind of file, a C3D .DWG file?
*Tips hat*
Since this feature has been exposed to .NET API as Partha demonstrates here, I should think this could be implemented in a batch processing operation using ReadDwgFile Method (untested), or even ported down into a custom LispFunction Method to expose .NET functionality to LISP API directly (example here, unrelated to this thread).
HTH
"How we think determines what we do, and what we do determines what we get."
If either of you decide to test this, be warned that there was a bug when using ObjectDBX or the .NET ReadDwgFile() with Civil3D drawings containing line/curve Tag labels and Tables. When these drawings are opened & saved in either manner the tables lose the links to the tags, so all tables end up empty. I last checked this at the initial release of 2014, so it may be corrected in 2015. However, since I first reported this in C3D2008, and it hadn't been corrected as of the 2014 release, I'm going to guess it wasn't at the top of the list of things to fix.
@Jeff_M wrote:If either of you decide to test this, be warned that there was a bug when using ObjectDBX or the .NET ReadDwgFile() with Civil3D drawings containing line/curve Tag labels and Tables. When these drawings are opened & saved in either manner the tables lose the links to the tags, so all tables end up empty. I last checked this at the initial release of 2014, so it may be corrected in 2015. However, since I first reported this in C3D2008, and it hadn't been corrected as of the 2014 release, I'm going to guess it wasn't at the top of the list of things to fix.
As always, thanks for the sound input, Jeff.
Whilst not as efficient as .NET batch process, nor ObjectDBX via LISP, perhaps then it would be more secure to instead simply implement the LispFunction Method and call via Script with the C3D drawing actually open in the editor.
..... When these drawings are opened & saved in either manner the tables lose the links to the tags, so all tables end up empty. I last checked this at the initial release of 2014, so it may be corrected in 2015. However, since I first reported this in C3D2008, and it hadn't been corrected as of the 2014 release....
