I am using C3D 2014.
I created an alignment mask in the alignments source file and referenced this file into a plan sheet. When I wanted to label the alignment, I noticed the alignment mask was not showing. Is there a problem with alignment masks showing as an x-reference or is there some setting I am missing?
Solved by CADEngr2014. Go to Solution.
Solved by Jay_B. Go to Solution.
Seems to be working here, the alignment mask does show up in alignment properties in sheet file where the Align file happens to be xref''d & dref''d.
Looking at the Alignment Properties in sheet file for Align "A" displays the masking which was applied in the Align "A" source dwg.
My situation must be something corrupt in the file. As a work around, I had to data reference the alignments and re-apply the masking in the new file, then turned off the alignment layer in the source file. I have xreferenced alignments with masking before and had no problems but not this time....Thanks for your time on this, at least I know its nothing I am missing.
