I have one seat of C3D where the user cannot show the AutoCAD toolbars. Everyone else in the office can access them from the Toolbars button in the Ribbon.
In the problem case the user can hit the toolbar dropdown and nothing will show. If he right-clicks on a blank toolbar area he sees the ACAD, CIVIL, EXPRESS entries. If he clicks the Civil the two transparent command toolbars are listed. If he clicks Express or Acad nothing pops out.
Tried a repair of the install with no solution.
The CUI shows these toolbars as loaded in the current workspace...
Anyone else see something like this?
John Mayo
Solved by rkmcswain. Go to Solution.
Solved by tcorey. Go to Solution.
Check your support file search path against a system that's working.
Tim, Randy,
Thanks. Another case of the incomplete support folder. Thinking this may be a windoze rights issue since it was one out of 20+ PC's that had the issue.
John Mayo
