rkmcswain
Message 101 of 127 (310 Views)
Re: C3D 2015 - List of Current Bugs/Issues
06-26-2014 11:22 AM in reply to: engrtech
engrtech wrote:
34. Confirmed Defect - When an OOTB C3D template is used, C3D will crash when you try to customize the scale list. Does not affect acad.dwt or any templates created from acad.dwt.  (nathan.hendrickson)
Started using 2015 this week and I think I've already exceeded the number of CER's from 2 years of using 2013.
I can't even SET the scale of a viewport now. As soon as I pick a scale from the dropdown list, a 2 second pause, then CRASH.
But the dark theme looks good, so I'd say it all evens out....
Valued Mentor
engrtech
Message 102 of 127 (265 Views)
07-01-2014 06:37 AM in reply to: engrtech
35. Confirmed Defect - Refill factor not working properly (fcernst)
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Confirmed-Defect-Refill-Factor-Not-Working-Pr...
Infrastructure Design Suite Premium 2014
Civil 3D 2014 x64
Testing IDSP 2015
Windows 7 64-bit
6GB RAM
Active Member
PowerCAD98
Message 103 of 127 (228 Views)
07-02-2014 07:47 PM in reply to: rkmcswain
I get the same thing as well but I've found that if i recover the file and create the scale factor within model space then change it, it works.  So far I'm so disapointed with C3d 2015.  I went to it from 2013 and I've lost 100s of hours of billable time due to the constant crashing.  it doesn't matter if its a project with a small data set or a large one, crash, CRash, CRASH all day long!  For the thousands of dollars we spend on this software this shouldn't be happening.
Now I'm being told that it's my screen size that's causing problems.  SERIOUSLY!!  I have one 28" monitor and my secondary monitor is a 24", been using them for 4 years with no problem and then now it's an issue.  I can only hope they are listening to us!!  I'm so over pulling all nighter just to do the same exact task 3-6 times to get a job done.
Sorry for the vent but I'm beyond frustrated!!
Yvonne Stillman
PowerCAD Inc.
Principal, Sr. Project Manager, CSI
rkmcswain
Message 104 of 127 (224 Views)
07-02-2014 08:22 PM in reply to: PowerCAD98
Who is telling you that?
What proof is there to back that up?
neilyj
Message 105 of 127 (215 Views)
07-02-2014 11:52 PM in reply to: rkmcswain
Yes - I'd be interested in the reasoning behind this assertion
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
rkmcswain
Message 106 of 127 (203 Views)
07-03-2014 05:22 AM in reply to: PowerCAD98
Also, can you go back to 2013? I agree that 2015 has a lot of problems, but it would be hard to rack up 100s of hours of lost billable time before I reverted back to something that worked. I suppose the choice to revert could be out of your control also....?
Lastly, keep sending in those CERs and creating subscription support tickets. Everyone has to let Autodesk know about the issues in order to get them addressed.
Valued Mentor
engrtech
Message 107 of 127 (198 Views)
07-03-2014 05:45 AM in reply to: PowerCAD98
Yvonne Stillman
PowerCAD Inc.
Before 2015 came out, the most buggy version of C3D I've ever used was 2013. 2014 works better than 2013 & 2015, but it has its own problems. The last really good version was 2012.
Civil 3D 2014 x64
Testing IDSP 2015
Windows 7 64-bit
6GB RAM
Valued Mentor
engrtech
Message 108 of 127 (189 Views)
07-03-2014 06:28 AM in reply to: engrtech
36. Confirmed Defect - Recent files list limited to 10. AutoCAD SP1 fixes this, but since it doesn't affect C3D we have to wait.
Civil 3D 2014 x64
Testing IDSP 2015
Windows 7 64-bit
6GB RAM
neilyj
Message 109 of 127 (182 Views)
07-03-2014 06:51 AM in reply to: engrtech
Perhaps not a defect as such as it doesn't affect the functionality; maybe more of an annoyance.
neilyj
Active Member
PowerCAD98
Message 110 of 127 (179 Views)
07-03-2014 06:58 AM in reply to: rkmcswain
I was told that the high resolution of my 28" monitor might be the issue. This was by a tech at CadMasters.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
