The ability to have Median assemblies cross Centerline has stlll not been restored in 2014. This was working in version 2013.
It was unacceptable to have the 2014 version be released without this working, and even more unacceptable to still not be addressed with SP1, and here entering November.
This was filed earlier this year as a defect. We need this capability for an urban corridor project ASAP.
So, Fred, are you gonna find a workaround or are you going to wait for Autodesk to fix it?
Tim,
Looking at this from the perspective of a designer with deadlines and budgets, how would you react to these issues when they occur over and over again?
Rick Jackson
Survey CAD Technician VI
I guess things like this are I look at two platforms for a project
if they are design dominant -> use InRoads for its roadway designer and templates
or plans production dominant ->use C3D for its labeling
Now if through some magic pot of stew, these two could get together...
@Neilw wrote:
Tim,
Hi Neil,
I'm not saying I like it when the software doesn't work as expected and I especially don't like it when it appears that errors are being ignored.
What I am saying is that it is important to be willing to work around the software's deficiencies because there will always be some. I have been working with AutoCAD, DCA, Softdesk, Land Desktop and now Civil 3D for twenty-plus releases, as both a user and as a reseller. There are always bugs. C'est la vie. It's an imperfect world.
Also, I don't think it's fair to rail against the inviduals at Autodesk who we consider to be "Senior Management." Even at that level, these are just working people like the rest of us. They come to work and try to do the best they can within the constraints imposed by their company. Has your boss ever told you no, you can't spend money on something you thought would benefit the company? Did you stamp your feet and say he should be fired or did you grit your teeth and go on with your job?
I am all for listing the errors here in the discussion group. That benefits everyone. What benefits no one is the angry tone of some of the posters.
Best regards,
Tim
...Has your boss ever told you no, you can't spend money on something you thought would benefit the company? Did you stamp your feet and say he should be fired or did you grit your teeth and go on with your job?...
How is this at all analguous to our perspective as Customers who are experiencing project downtime and loss of profitability due to continuing cyclical product defects and lack of quality control management with the design software that we have a significant and ongoing substantial monetary investment in?
Oh I agree with you are saying Tim. My point was when we as users encouter these defects it is very disruptive and often leads to hours or even days troubleshooting or finding a workaround. So simply saying go look for a workaround doesn't address the issue.
How we go about expressing the problem to the developers is another matter.
Another way of saying it would be, "When things don't go your way, do you stamp your feet and act petulant or do you get on with the work at hand?"
or
"If your tire blows, do you kick the tire and scream at the wind or do you go to your trunk, get your jack and get back on the highway?"
Anger doesn't help get the job done.
Tim
What is your workaround for this Tim?
It needs to be as easy, and no more time consuming, as it was to do when it was working in earlier versions of the software.
I had the same problem with my medians, and have figured out a fix for this!!
After 2 days of reworking corridors, rebuilding assemblies, and beating my head against the wall, I decided to start playing with some of the features in the corridor properties that I have never touched before. Come to find out, the fix to this is to change ONE setting and it fixes the whole corridor. See below...
Once I changed this from Inward to Outward, and rebuilt the corridor, it worked like a charm.
This has been logged as a defect by Autodesk. See the link below.
I tried your Branching setting suggestion, and I still get incorrect Corridor and Corridor Section construction when crossing the Centerline. See the image below.
yeah although branching does fix the whole feature line cutting the wrong way thing.. it still leaves a hole in the featureline where it crosses the centre line..
MY solution is rather simple. develop your corridor off a different centre line. Its kind of annoying as it plays with you chainages but still it works.
Kapanther
