I open two different drawings, I'll call X and Y. I make X current. Using the setting tabs of the prospector I go to Y drawing and click the plus and open the styles i want to insert into X drawing. So for example I open <General <Label Styles <Note Elevation and drag that style into my X drawing. I go and look at my X drawing <General <Label Styles <Note and see that Elevation is not there.
I have tried using AeccImportStylesAndSettings and also I'm running the sincpac which has an import civil styles function that does not work either. I went to a co-workers machine and he can get the styles import function to work just fine.
So any thoughts as to why I may not be able to get this to work? I even tried to create a new layout from template and still could not get beyond the styles that are default to my current drawing. My only option is to create the styles manually and that is, well, NOT AN OPTION!
Solved by Jeff_M. Go to Solution.
Rick Jackson
Survey CAD Technician VI
Yes ran the audit and no error messages. This is happening on all my drawings so not just this one. Something wrong with my settings or computer as I said a co-worker has to import styles into the drawings from his computer. Same drawing on the same network.
Rick Jackson
Jeff sorry but I assumed that I had run an audit. I just ran it and it fixed the style import problem. Thanks for the help and you too jackson
