Civil 3D Forum
C3D 2013 to C3D2014
5 REPLIES 5
rwatson654
312 Views, 5 Replies
C3D 2013 to C3D2014
We would like to run both 2014 and 2013 within our office.  I understand 2014 is suppose to be the first version of Civil 3D that is completely compatible with an earlier version, 2013.  I need to know if things like styles, survey database etc. will work both ways between 2014 and 2013.
I saw an earlier post on this pertaining just to the survey database but would like to see if any issues have come up since and/or if there are problems in other areas.
C3D 2013 (latest updates), 2014 Infrastructure Design Suite
Win 7 Pro, 64-bit
16 GB RAM
5 REPLIES 5
dgorsman
in reply to: rwatson654
I wouldn't say "completely compatible".  Rather, it can be opened and will function reasonably well.  Personally I wouldn't try to mix versions in a single office, if only for the support headaches, and this being the first kick at the can.  Better collaboration with other companies and meeting client requirements is where I see this being right now.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
rwatson654
in reply to: dgorsman
Thanks for the reply.
I should have stated the only reason for the mixed environment is to evaluate 2014's benefits vs upgrade cost.  Only one system will have 2014.  I just want to be aware of any issues between the two versions to avoid problems with projects.
Jay_B
Here's an older thread re: Interoperability 2014 to 2013, including some limitations and issues folks have ran into.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
rwatson654
in reply to: Jay_B
Thanks.  Missed that one when I was researching. Sounds like the 2014 files should be isolated from those using 2013.
Jay_B
Agreed.
C3D 2018.1
C3D 2016 SP4
Rail Community
