Seems like all my existing dll's won't work in C3D 2013 without some code alterations - fantastic......!!!!!!
A small QA point - someone didn't check the names on the panels to ensure consistency. I know its a minor thing that's easily fixed but come on AutoDesk
neilyj (No connection with Autodesk other than using the products in the real world)
Many customization files targeting C3D have needed to be recompiled for new versions every year. Those that didn't were able to be done using strictly .NET API.objects. But the AutoCAD 2013 API has undergone major changes, and C3D2013 has also made major changes in the API. So ALL .NET DLL's wiil not only need to be recompiled for 2013, but they will also need to undergo some code updates before compiling.
Not sure I'm seeing what you are about the names.
@Jeff_M wrote:Many customization files targeting C3D have needed to be recompiled for new versions every year. Those that didn't were able to be done using strictly .NET API.objects. But the AutoCAD 2013 API has undergone major changes, and C3D2013 has also made major changes in the API. So ALL .NET DLL's wiil not only need to be recompiled for 2013, but they will also need to undergo some code updates before compiling.
..thus rendering all the dll's I use in 2012 useless.....
Inconsistency with the naming i.e TRIM rather than Trim and fillet rather than Fillet - I've got the European English version so could be different to yours. I've fixed it now anyway - and put the Volumes calculation back on the Ribbon
Jeff
A few months ago you modified some Autodesk supplied code to run as a dll (C3D Working Plane) - would you be able to update for 2013??
That'd be great if you could manage it,,,,my subscription download worked first time using the download manager today
