C3D 2013 UK/Europe
In an Alignment Style, Marker option: Chainage Reference Point
What is this (Chainage Reference Point) ?
When does it occur?
Please provide an example.
I tought it was a chainage equation... but then it would be named 'chainage equation'
.. it is not a chainage equation (at least ... I dont thnk so) ???
Thx.
Kevin.
Solved by kbarnettza. Go to Solution.
found it ... it is the Alignment Reference Point, usually the start of the Alignment but can be a different position as required - the Alignment Chainage Reference Point is the starting position of the start Chainage.
