Civil 3D Forum
C3D 2013 - Surface transparency (elevation)
31 REPLIES 31
Message 1 of 32
diegoal
12877 Views, 31 Replies
Hello all,
In the previous C3D 2012 version I was able to set surface transparency just setting it on a layer with defined transparency. Example: I set my "existing ground" surface to a created  "EG" layer (example name) and set transparency layer to 50% (example, again) and it WORKS! My surface become transparent...
But now, in the C3D 2013, I can't get the same results... my surface is not getting transparent. I already tried to turn off/on hardware acceleration and adaptive degradation and show/hide transparency.
More details: I can get transparency on points, triangles, contours etc... but not on elevation, and this is my priority.
Thanks very much and sorry for my bad english,
Diego Álvares
Civil Engineer @ Trento Engenharia Ltda.
www.trentoengenharia.com.br
Autocad Civil 3D 2010 to 2017 - Infrastructure Design Suite
Windows 7 64 i7 4770 @3.40GHz 8GB Ram GeForce GTX 760
Please use the Accept as Solution or Kudo buttons when appropriate
31 REPLIES 31
Message 21 of 32
ezick
in reply to: diegoal
thanks for the discussion.  Hardware acceleration 'on' was the difference maker.
Message 22 of 32
autoMick
in reply to: ezick
Folks - I'm after an update on this topic.
I have the same issue - I have a volume surface displayed as 2D elevation. I wish to make this surface display 50% transparent (overlay on aerial photograph), I've tried the suggestions in this thread to date. My graphics card is a consumer nvidea card rather than quadro, but I really doubt that is the issue. Have Autodesk fixed the problem that they acknowledged in neilyj's post?
- Mick
Civil3d user in Australia since 2012.
Message 23 of 32
neilyj666
no still doesnt work. they are too busy catfarting around with the likes of infrastructure modeller to address the bugs introduced in 2013. perhaps service pak will
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 24 of 32
neilyj666
...fix it but im not holding my breath on this as usual
Message 25 of 32
autoMick
in reply to: neilyj666
I guess we'll just have to wait for this elusive service pack then...
Message 26 of 32
neilyj666
no guarantees of it being fixed.......
Message 27 of 32
rbunner
I noticed that this still hasn't been fixed.  Very disappointing since I switched over to 2013 and I KNOW it worked well in 2012.  I use the transparency for the elevation all the time so that I can use images and other features in the drawing.  PLEASE FIX!!!Smiley Frustrated
Message 28 of 32
diegoal
in reply to: rbunner
Yes rbunner, no fix at all.. I can't understand why they went backwards like this.
I tried to change Visual Style to realistic or shaded... I was able to get surface transparency but it demands a lot of my processor or graphic card... Can't work with this...
Let's see the C3D 2013 SP2...
Diego Álvares
Message 29 of 32
ceethreedee.com
We are now in 2013 and i am sure all of you are awaiting a fix for this. I am now well and truly sick of exploding my surfaces to get transparency to work in them.
Looking forward to update to fix!.
Kapanther
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
Message 30 of 32
rbunner
Does anyone know if this has been fixed in 2014 or 2015?
Message 31 of 32
diegoal
Yes. C3D 2014 fixed this problem, but in a different way.
Now surface transparency is given by elevation or triangle layer
transparency.
Diego Álvares
Message 32 of 32
HQGL01
This worked for me, changing layer transparency.
Thank you!
Rail Community
