AutoCAD Civil 3D General
Active Member
Message 11 of 31 (670 Views)
Re: C3D 2013 - Surface transparency (elevation)
06-15-2012 07:44 AM in reply to: diegoal
I do not know why but I can not turn it on...
You think that is problem of my drawing?
Valued Contributor
Message 12 of 31 (667 Views)
06-15-2012 07:48 AM in reply to: 0805110786
What can't you turn on?
Transparency control, hardware acceleration or surface transparency?
I guess it can be hardware problem... what is your graphic card and PC configuration?
Diego Álvares
Civil Engineer - www.trentoengenharia.com.br
Autocad Civil 3D 2013 / 2014 - Infrastructure Design Suite
Windows 7 64 i7 860 @2.80GHz 8GB Ram Quadro 2000D
Active Contributor
Message 13 of 31 (665 Views)
06-15-2012 07:50 AM in reply to: 0805110786
Sorry, yeah, the transparency is in the layer not the suface. Too early to think clearly apparently.
Also, once you get it working, to plot, make sure "plot transparency" is checked in the plot dialog...
Civil 3D 2013 - Windows 7 Pro 64 - Dell T3500 - Xeon 2.67 - 24gb - Quadro 600
Active Member
Message 14 of 31 (663 Views)
06-15-2012 07:56 AM in reply to: JonRusk
My graphics card : Intel (R) Graphics Media Accelerator HD
Processor: Intel (R) Core (TM) i5 CPU 650@3.20 GHz 3.33 GHz
Active Contributor
Message 15 of 31 (657 Views)
06-15-2012 08:28 AM in reply to: 0805110786
I think you might need to get a dedicated graphics card, especially when working with surfaces and such...
http://www.tomshardware.com/forum/243783-49-autocad-integrated-graphics
http://www.tomshardware.com/forum/320416-33-integrated-graphics-discrete-graphics-card
*Expert Elite*
neilyj
Message 16 of 31 (654 Views)
I've tried this in 2012 - Created an EG on Surface named C-SURFACES-EG and set Transparency to 50% - works as expected.
Tried Plot preview and turned on Transparency - Plot previews as expected
Tried in 2013 and no transparency is honoured although plain CAD hatches transparencies are honoured.
Lets see them rush out a fix for this......NOT:smileyfrustrated::smileyfrustrated: How can this one have missed  the quality control prior to releasing 2013??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Active Member
Message 17 of 31 (631 Views)
06-17-2012 08:33 AM in reply to: JonRusk
Thanks Diegoal an JonRusk for helping :smileyhappy:
I know I need better graphics card, but I did not think that is problem because it is not shows transparency, because does not seem to me "bigger" job for card then doing elevation analysis which I could do?
I will try it  tomorrow on better computer and I hope it will work :smileyhappy:
Valued Mentor
Message 18 of 31 (612 Views)
06-18-2012 10:06 AM in reply to: 0805110786
The problem is that you don't have a graphics card to begin with.  Integrated graphics chips are not very good and have to share the system's RAM.  It won't matter the job size, sometimes the integrated graphics chips just won't do things like hardware acceleration and display items correctly.  That's why you'll mostly get responses to get a dedicated video card.
Infrastructure Design Suite Premium 2014
Civil 3D 2014 x64
Windows 7 64-bit
6GB RAM
*Expert Elite*
neilyj
Message 19 of 31 (585 Views)
06-22-2012 08:06 AM in reply to: neilyj
Further to my previous post, Autodesk have confirmed that they broke this in the 2013 release...
"Thanks for your reply and for supplying the drawing file. I confirm this is an issue with the 2013 release of Civil 3D.
I have documented the problem and submitted the file to the development team for them to look at the issue more closely.
One workaround that can be used for the time being is to switch to the "Wireframe" visual style, which will honor layer transparency settings. However this is only applicable to the viewport and the transparency will still not be honored when plotting.
For the plotting we don't have a workaround for the time being."
neilyj
Active Contributor
Message 20 of 31 (528 Views)
08-09-2012 11:45 AM in reply to: diegoal
If you are effectively trying to fade the surface back, a possible workaround could be to draworder the surface to the back, put a hatch on top of it with a transparency and with a color that prints at 0% screening. It's not the same thing as a transparency but close.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
