I just had C3D 2013 reinstalled on my LT and having a surface visibility issue. This may be just a command setting issue but I have a surface and created it on a particular layer that I can't make invisible.
Then I turned that layer off so I could work on other things. Now when I do a REGEN that surface becomes visible in my drawing yet the layer identified in its properties is turned off.
If I got to VIEW and ORBIT the surface disappears until I stop rotating then it’s visible again. I like to control visibility by turning layers on or off but this isn’t allowing me to turn it off.
If I make the surface layer current and do a rebuild the surface moves back to that layer and I can then turn that layer off to make the surface invisible.
Why is this surface visible when its layer is turned off?
Solved by troma. Go to Solution.
Mark Green
Working on Civil 3D in Canada
You might be on to something. Forgive the silly question but how do I make the triangles and contours stay on the same layer as the surface object?
I don't remember this being an issue in the past so I assume the template I'm now using is set up different.
Mark Green
That may work but what if I want to use that same style for another surface? It seems I'd have to make a style for each surface and I don't think that how it was setup before when I wasn't having this problem.
I now have two surfaces in my drawing and everytime I do a regen they both become visible on the current layer.
Have a look here:
That might help you.
Or you could use the suggestion later in that thread to just 'hide objects'.
I'm not sure how a surface could physically change the layer it is on from a regen, are you sure that's what's happening?
Mark Green
Mark Green
According to an article I read from Eagle Point, if the style calls out 0 like the picture above, it does not get drawn on layer 0 it gets drawn on the layer that the surface itself is on.
Have you tried object layers? I'm usin C3D2013 and control the displaying of my surfaces the same way that you do and haven't had any problem so far. Maybe this would help, this would cause all TIN surfaces you create to go into a different layer named after that surface. And if you hide the layer, the surface does not display regardless of the style you're using:
Thanks for the tip.
I just tried and it didn’t seem to work for me.
I applied those setting then selected the surface layer as the current layer.
Then did a rebuild and the triangles were drawn on that surface layer.
I then selected a different layer as the current layer and turned off the surface layer.
Then did a regen and the triangles appeared on screen in the color of what is the new current layer.
Maybe layer control isn’t the way to control surface visibility. I got into that habit from Terramodel. Another source of problems may come the new template I’m now using. It had hundreds of layers I didn’t want so I used LAYDEL to get rid of them. It seems there are setting that refers to those deleted layers. I’m new to C3D and when playing with it a few months back I though at that time I could control visibility with layers. I had a drawing with 3 surfaces and I don’t remember having the issues I’m now having. It might have been the template I used at that time or I may be wrong in what I’m attempting to do.
Mark Green
Yeah I can now control surface visibility by turning style to none so I can get by for now. I though I was doing okay but seems I have a lot to learn about C3D.
Mark Green
I just checked and there was no layer selected it was just blank. I guess because I had deleted all the template layers. So under Surface Style / Display I selected layer 0 for all listed unser Component Type and it seems to work. I turn off the surface layer and do a drawing regen or surface rebuild and I don't see anything related to that surface. I don't know why I missed that yesterday.
Seems the other surfaces stay on there layer also.
I better make a note of this, I could see myself scratching my head about this one again in the future.
Thats the solution
Thank you.
