AutoCAD Civil 3D General
Active Member
johnfraser
Message 21 of 31 (901 Views)
Re: C3D 2013 Hotfix 2 released
09-03-2012 03:32 PM in reply to: neilyj
Ok, so when I started up my system again this morning I was getting four error messages on C3D Metric startup (3 attached). I also couldn't seem to open any drawings without crashing. Like before, C3D Imperial seemed to work fine.
So, I reset the profile again, and was no longer getting the error messages. I didn't bother too much about trying to get my settings back yet, in case the same thing happened next time I booted up. So I restarted my machine, and it seems to still be working ok in that respect. EXCEPT that I seem to have lost the C3D workspaces, meaning that I can't access any of the C3D specific menus. I just have the standard AutoCAD workspaces. Even when I open up the CUI I can't see the C3D ribbon tabs.
If I open C3D as Imperial however, I still have the C3D workspace/menus etc. What is going on??
Active Member
johnfraser
Message 22 of 31 (881 Views)
09-03-2012 07:24 PM in reply to: johnfraser
So, 5 hours later. C3D Imperial is now behaving the same way that C3D Metric was this morning - i.e. giving error messages during startup and then getting stuck trying to open any drawing.
C3D Metric is still not giving me C3D menus, and (seemingly since opening up C3D 2012 briefly) is now giving me the same error messages as yesterday, and having a fatal error when I try to open any drawing.
I had not had any problems with C3D 2013 (other than semi-frequent crashing) prior to installing this hotfix.
Message 23 of 31 (780 Views)
09-07-2012 05:03 AM in reply to: johnfraser
I hope my problem is related. I have C3D 2013 and have installed hotfix 2. I have the problem that C3D 2013 crash when I try to load a C3D 2012 drawing. Loading the drawing with C3D 2012 gives no problem. This problem occurs also when I want to attach an earlier version drawing to a C3D2013 drawing.
As background to my computer: I am working in metric, have a i7 CPU, 16 GB memory, standard NVidia screen card, 2x 22" monitors and at least 1TB HDD available.
I notice from Autodesk site that I can no longer download hotfix 2 (or 1 for that matter as it points to hotfix 2's addy). I am a subscription owner (not that it means anything if you have so many problems with an upgrade as what C3D 2013 realised to)
Thank you
Geurt
Geurt Bloem Pr Eng
Autocad C3D
*Expert Elite*
neilyj
Message 24 of 31 (772 Views)
09-07-2012 07:06 AM in reply to: johnfraser
Interesting that the hotfix has been pulled and is not currently available.......seems to vindicate all the posts indicating problems with it...!!!!:smileywink:
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 UKIE SP1 & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
*Expert Elite*
DarrenP
Message 25 of 31 (769 Views)
09-07-2012 07:20 AM in reply to: neilyj
i just noticed that
the autocad 2013 service pack was pulled and now the civil 3d 2013 hotfix 2 is being pulled
*Expert Elite*
neilyj
Message 26 of 31 (760 Views)
09-07-2012 08:46 AM in reply to: johnfraser
I think the AutoCAD service pack was pulled due to security checking issues with LISP and VBA macros but no idea what happened with hotfix 2
neilyj
*Expert Elite*
Message 27 of 31 (729 Views)
09-07-2012 12:29 PM in reply to: neilyj
neilyj wrote:
I reset the C3D_UKIE profile in Options > Profiles and all seems ok again.....so far
Sorry for such a lengthy post but I'm not sure Reset should be used with a vertical product and here is why.
I don't believe AutoCAD/Civil3D has any functionality built in to reset a profile to a shipping vertical product profile. How would you know what you are resetting to, Civil 3D comes with quite a few profiles? Hoping that it resets a profile to a shipping profile of the same name is a bit of a stretch IMHO.
Likewise the "Set Current" button really is a bit of a misnamed button in a vertical product because the shortcut you use to start Civil 3D specifices a specific profile indepentdant of what you may have previously "Set Current".
I have a profile called "<<C3D_Metric> Default" which I renamed from an uncustomized "<<C3D_Metic>>" after running Civil 3D for the first time. I have an exported custom profile ARG file that I import and rename to <<C3D_Metric>> so when I run Civil 3D from the default metric shortcut I get the our custom profile.
So if I take "<<C3D_Metric> Default" and make a copy of it to "Copy of Original <<C3D_Metric>>" and then export both I should get the same ARG file (except for the profile name) right? It is close but the following keys are missing. The keys are empty so not a huge deal assuming Civil 3D will recreate them as needed but it shows there is not a lot of attention to detail in this area.
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\Profiles\<<C3D_Metric>> Default\Dialogs\CustomizeDialog\TabExtensions]
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\Profiles\<<C3D_Metric>> Default\StatusBar]
Now if I take "Copy of Original <<C3D_Metric>>" and make another copy to "Reset of Original <<C3D_Metric>>", reset THAT profile, and then export it to an ARG and compare then the fun really begins.
Copy of Original:
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\Profiles\Copy of Original <<C3D_Metric>>\Defaults\AecBase70]
Reset of Copy of Original:
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B000:409\Profiles\Reset of Original <<C3D_Metric>>\<<C3D_Metric>>\Defaults\AecBase70]
So you can see that the registry key path has an extra key in there named "<<C3D_Metric>>" which I pretty sure means Civil 3D can't read it.
Also, if I look at my workspace list all I have is the default AutoCAD workspaces, no Civil 3D workspace, no Civil 3D ribbon tabs.
At this point I think all I'm getting is mostly just AutoCAD, a little bit of Civil 3D, and a lot of missing settings (the 'reset' ARG file has lost 15% of its content).
Here is a typical support path for Civil 3D:
Here is what I get after resetting the profile (looks a lot like vanilla AutoCAD to me):
*Expert Elite*
neilyj
Message 28 of 31 (723 Views)
09-07-2012 12:37 PM in reply to: GTVic
Thanks for this comprehensive analysis - all I know is that my C3D worked properly after the reset profile.
Perhaps the hotfix broke more than it fixed (as seems to be the case more often than not with Civil 3D these days)
neilyj
*Expert Elite*
Message 29 of 31 (637 Views)
09-10-2012 10:37 AM in reply to: johnfraser
You may want to check your support file search path and at least add in the last three folders which may be missing.
*Expert Elite*
neilyj
Message 30 of 31 (632 Views)
09-10-2012 11:37 AM in reply to: GTVic
All seem to be present and correct....
neilyj
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
