Civil 3D Forum
C3D 2012 & Etransmit
19 REPLIES 19
Message 1 of 20
Lisa_Pohlmeyer
1271 Views, 19 Replies
I've noticed a strange behavior in my Temp folder. There appears to be several etransmit_xxxx.dwt files. I haven't used that tool for months, yet there's even one dated today. Wassup with dat? Now I realize that a dwt is a template file, and I don't even have a template for Etransmit. What's creating these files?
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Tags (1)
19 REPLIES 19
Message 2 of 20
Are you syncing your settings with Autodesk 360 by any chance?
Todd Rogers
Message 3 of 20
No, I have that service turned off for all our workstations.
Lisa Pohlmeyer
Civil 3D User
Message 4 of 20
Yeah I definitely do as well.  I am not sure what would cause that.  Pretty strange.  I don't see anything like that in my temp folder.
Todd Rogers
Message 5 of 20
Jeff_M
in reply to: Lisa_Pohlmeyer
Lisa, I think these get created when using the Publish command. They usually get deleted when the command completes, but sometimes they remain, possibly if the Publish command encounters errors.
Message 6 of 20
neilyj666
Happening for me in 2014 as well - not used etransmit for ages
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 20
Jay_B
Lisa,
I have the same mystery files here. No idea how they are being created other than they are all relatively early in the day (possibly a startup thing)? Even have one from this morning.
I have not used etransmit recently either nor am I syncing to 360 that I'm aware of. I agree this seems strange.
Civil 3d 2012 SP3.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 8 of 20
Jay_B
in reply to: Jeff_M
Hmm, I've not used publish but plot through SSM and haven't done so yet today but have an etransmit-tmp.dwt from today.
C3D 2018.1
C3D 2016 SP4
Message 9 of 20
neilyj666
in reply to: Jay_B
I've opened drawings that are part of a sheet set but haven't plotted or publlished them
Message 10 of 20
It seems that these started appearing in about January 2011 (yes, I have a Map 3D user who hasn't cleaned out his temp folder in awhile.) That was so long ago, that I can't even guess what triggered it. They're all the same size, 64KB, and they're sequentially numbered.  This is really strange. Hope Autodesk chimes in. Perhaps a platform issue.
Lisa Pohlmeyer
Civil 3D User
Message 11 of 20
neilyj666
One of these files has just been created on 2014 on start up this morning
Message 12 of 20
MikeEvansUK
in reply to: neilyj666
Exactly the same here but from 2013, I have 2014 installed but rearly use it for anything. Mainly open it by mistake.
I have a 30.5kb dwt file created when I started 2013 this morning & none since. I have traced another file from a system restore point dated 1st July 2013. Furthest I can go back.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 13 of 20
rmacan
Has anyone ever found out the reason these files are created, and not deleted when AutoCAD is closed?   My TEMP folder has over 125 of these etransmit*.dwt files in it.  I've used etransmit once in the past couple months.
I'm running ACAD MAP 2015, so evidently Autodesk doesn't have this issue on their to-do list.  I thought it would have been fixed by now.
Message 14 of 20
C3D_TomR
in reply to: rmacan
I have several temp folders mapped to separate folders (other than %temp%) so I can track them. The etransmit-tmp#.dwt files are on my computer as well and they are being saved to the folder assigned to the Temporary Drawing File Location on the Files tab of the Options dialog. Other files being saved there as well are ACA#####.ac$, Civil.cdc, RED#####.ac$, and UND#####.ac$
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Message 15 of 20
Jeff_M
in reply to: rmacan
I believe those dwt files are created when Publishing a set of drawings.
Message 16 of 20
C3D_TomR
in reply to: Jeff_M
Nope. I have only opened and closed drawings today as well as saved, drew polylines, deleted objects, etc. Not a single plot or publish. Only accessed a layout tab one time today. Created a viewport using mview command then back to modelspace.
Tom Richardson
Twitter | LinkedIn
Message 17 of 20
Jeff_M
in reply to: C3D_TomR
So much for my S.W.A.G. Since I never use eTransmit, but do Publish often and have lots of those files in the Temp folder, that was the basis of my guess....
Message 18 of 20
C3D_TomR
in reply to: Jeff_M
At least that's one thing that can be possibly eliminated.
Tom Richardson
Twitter | LinkedIn
Message 19 of 20
BlackBox_
in reply to: Jeff_M
Just stumbled upon this thread searching for any reason, or root cause for the undesired behavior I've been experiencing - IDSP 2014-2016, mostly using Civil 3D 2015 at the moment.
Long story short -
I'm frequently seeing the active document write-protected upon SAVE, and end up having to instead save somewhere else (my Desktop; local SSD, etc.), and then back to network.
More info here... http://www.theswamp.org/index.php?topic=50185.0
Not sure if these eTransmit*.dwt files are related, but I've never used that command, nor PLOT, or PUBLISH frankly (Autopublish only) - I am seeing these as well, but they do seem to be removed following a successful save - now if I could just figure out why they become write-protected while I have it open!? Grrr
Cheers
"How we think determines what we do, and what we do determines what we get."
Message 20 of 20
Peter2_1
in reply to: BlackBox_
Something new with this?
I just found it on my Map 2018, when attaching a XREF. It seem to be created once per Acad session when x-refing the first time, stays unmodified when usign new xrefs on new drawings and is deleted when Acad is closes
AutoCAD Map 3D 2023 German / Oracle
Rail Community
