In the same vein as this: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/C3D-2012-Figure-Style-Slow-to-Respond/m-p/3005214#M15..., I have run into the same slow response when selecting the Parcels in a Site in Prospector.
I first noticed this in my own drawing containing 4 sites, 3 of which have 1 - 6 Parcels, and the other has 170 or so Parcels. When I selected the word "Parcels" in the large Site, C3D went into a limbo state for approx. 7 minutes. I received a phone call just after I figured out it was not going to let me do anything so I just let it sit. I did open Task Manager and saw that acad.exe was consuming 100% of one of the cores. Much to my surprise, during said phone call, I watched C3D come back to life and the Graph View showing the parcels at the bottom of Prospector filled. As soon as I clicked the word Parcels again it again went into that limbo state. I can click any other branch in a Site without a problem, but clicking on Parcels will 'freeze' C3D everytime.
I can duplicate this in any one of the Parcel* tutorial drawings as well.
Then I tested with another C3D Profile and it has no problems selecting Parcels. So I switched Profiles using Options to my usual profile. Selected Parcels, this time it did 'hang' but only for a few moments. Clicked another SIte, clicked Parcels, hung for 2 minutes or so.
So it looks like I've narrowed it down to being Profile specific, but I'm not sure what I could have changed in the 'bad' one to make it 'bad', as I just created it last week from a copy of the 'good' one.
Solved by AlmasSuljevic. Go to Solution.
Thank you Jeff_M
I have just informed our I.T department who promptly installed the service pack, unfortunately I opened a drawing to check if it is any better and having tried to load up a pipe network on there and it taking almost 5 minutes then almost crashed my machine I realise that the service pack isn't the miracle fix I was hoping for.
Thank you for your response though it was certainly worth a try
@Jeff_M wrote:O.Maile & Dave 1982, have either of you installed the Service Pack released last week? I have not experienced any of these slowdowns in Prospector since installing it.
Jeff
At the risk of hijacking this thread for another purpose, I see you have installed SP1 - have you tried the DRIVEcommand?? Load up Corridor 5A.dwg from the Tutorial Folders and see if it works (I'm having major annoyances with DRIVE)
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Odd-behaviour-using-DRIVE/td-p/3236916
neilyj (No connection with Autodesk other than using the products in the real world)
Will install the service pack this evening and see how it goes.
Anyone else slightly annoyed by the fact that solutions can't be unmarked when they don't work, maybe a new thread is required here...
@Jeff_M wrote:Yes, I'm seeing the same 'not quite right' behavior with DRIVE.
Thanks for checking it out - I have a Support Request raised on this......
There is a problem with SP1 and DRIVE acording to Autodesk :
"...Ok, thanks for the details.
I did some more test and can confirme the issue.
Yes, unfortunately, the issue you mentionned is a "side effect" of installing Update1.
I will report this issue to our dev. team.
For now, I would say keep the mous in the drawing area if this is acceptable for you. If not, then you may have to use Civil 3D without update1.
Thanks a lot for reporting this issue.
Please let me know if that answer your question or if you need more details from my side.
Best regards,..."
To my understanding, there were three issues raised in this thread:
1. The lag/CTRL issue that was solved by the horfix.
2. The issue of pipe networks operating slowly in toolspace.
3. The DRIVE command with service pack 1.
I am having the second issue (pipe networks move REAL slow in the Toolspace - Prospector preview) and am aware that the problem was being looked into. Has a solution been found yet?
I am currently using C3D 2012 SP1.
Thanks.
Good news is that issue #2 (pipe networks operating slowly in toolspace) has been resolved for a future release. At this time I cannot provide any more specifics, sorry!
hgohel
Fixed for a future release?
I do hope you refer to a future release of a software update or hotfix rather than an updated version of the program?
I would imagine it would upset rather a lot of users to think they have spent money on a sub-standard release that wasn't tested properly only to have to purchase the next release to see an improvement?
....and still no fix for the DRIVE command.....!!!!!
