Civil 3D Forum
C3D 2012-Project Objects to Section View-3DSolids appear reversed/mirrored
0 REPLIES 0
Message 1 of 1
vpsgomes
240 Views, 0 Replies
I have encountered the following situation (bug?):
I have a 3D Solid representing a retaining wall.
I tried to project the solid to a section view using Civil 3D command (Project Object to Section View) but it appeared reversed or mirrored. Although the wall appear on the correct side of my alignment the projected objected is drawn the wrong way.
Curiously, if I invert the stations on my alignment (the default alignment was drawn from South to North, as required by my client) to a South-North orientation the wall appears correct.
Problem detected using Autodesk Civil 3D 2012 Update 1 and persisting in Update 2.
0 REPLIES 0
Rail Community
